10-10-2020, 09:35 AM
Hi all,
While waiting for the next episode of the Steen's HEPAX Treasure Chest, I decided to go a bit deeper inside my HEPAX module; namely inside its EPROM content.
It uses a standard UV erasable 27C256 chip. Later models use the OTP PLCC version.
The ceramic PCB has pads on its sides that allow reading and even in-circuit programming so I built a "dirty" fixture in order to access the EPROM directly.
[attachment=8787]
(Probably unnecessary, but just in case: Do not try this at home! :-D)
I knew HEPAX only use 5 bits (b0-b4) of every byte to build every HP-41 10 bit word.
The way it handles this arrangement was however a bit surprising.
Most EPROM boxes place the MSB on the even byte of the EPROM and the LSB on the odd byte; much like the .ROM file format.
HEPAX on the contrary places all (5) LSbs of a given page on the lower 4K of this page while the upper 4K hold the (5) MSbs.
An example of that may help to clarify.
[attachment=8788]
The four banks of the HEPAX code are sequentially stored in the 32K of the EPROM.
Best wishes from the Canary Islands and enjoy your weekend.
Diego.
P.S.: The HEPAX module in the picture above survived the procedure and is comfortably sitting in my CX port 1. ;-)
[attachment=8787]
[attachment=8788]
Diego.
