10-05-2020, 01:55 PM
I have designed and 3D printed a replacement case and cover for the Hand Held Products 71 M/M series of card reader port memory modules. If you have a naked module or your original case is broken or lost this may be of interest to you.
I re-designed the module cover so that the "side wings" are thicker and hopefully less fragile.
Here are some photos:
https://www.dropbox.com/s/sjni333n67alhu...0.jpg?dl=0
https://www.dropbox.com/s/i9cidbupg1ab9a...0.jpg?dl=0
https://www.dropbox.com/s/16d4ui6w85l2vs...0.jpg?dl=0
https://www.dropbox.com/s/blh8qi2d1c11ty...0.jpg?dl=0
https://www.dropbox.com/s/2814d7f8j6ndcv...0.jpg?dl=0
https://www.dropbox.com/s/ycj54xgf3rzf65...0.jpg?dl=0
https://www.dropbox.com/s/je5uc8qbh2uckx...0.jpg?dl=0
https://www.dropbox.com/s/grylf1rhxzik78...0.jpg?dl=0
This will include the two halves of the case, the cover with the anti-static foam inserts as in the original, and an optional custom engraved insert (you supply a PDF of your artwork or a sketch and I will make a final design for your approval).
These were designed around the HHP Modules. I don't know if the CMT Modules will fit.
I will not be putting these on eBay. If you are interested, send me a PM for further details.
