09-29-2020, 09:39 AM
Hi guys,
I'm having issues with running Emu48+.exe (1.61) ARM-based calculators interfering with the other Emu48.exe (1.62) Saturn-base. I'm using RealCalc-3.0 KML skins.
I've been using HP50g skin ARM-based Emu48+.exe, but when I'll try using Saturn-base Emu48.exe to load up the KML skin for HP48g the KML will not show in the drop-down list, it tries to continue using Emu48+.exe even though I clicked on Saturn-base Emu48.exe.
I work around this by installing standalone portable copies and it worked for a short time but now it started to interfere with each other.
I Know I can rename 49g instead of the 50g and only use Emu48.exe (1.62) Saturn-base but I don't want to do this.
Is there a reason why this happening and a workaround?
Thanks in advance.
Thanks in advance.
