HP Calculators (and very old HP Computers)
HP Prime
> exponential simplification
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
KeithB
09-23-2020, 01:16 PM
I was doing some fuse i-squared-t calculations last night and found that when you use the CAS to multiply exp(x) * exp(x) you get exp(x)^2 and not exp(2x). Is there a way to get the CAS to do that simplification?
ramon_ea1gth
09-23-2020, 04:46 PM
The CAS command "lin" (from the catalog) does the work.
The "lin" command should be listed in the menu "CAS/Rewrite/Exp & Ln" from my point of view.
KeithB
09-28-2020, 02:01 PM
Thanks!
HP Prime
HP Forums:
https://www.hpmuseum.org/forum/index.php
