These units use the same battery pack:HP97, HP91, HP92, HP95C, HP82143A / HP82182A Printers, and HP83261A .
Can someone verify if there is any commonality in battery doors among these?
Thank you,
TomC
(09-12-2020 12:43 PM)TomC Wrote: [ -> ]These units use the same battery pack:HP97, HP91, HP92, HP95C, HP82143A / HP82182A Printers, and HP83261A .
Tom,
I am assuming that you mean: HP-91, HP-92, HP-95C, HP-97, HP-97S, HP-82143A, HP-82161A & HP-82162A.
I just tested it, although the color is different between the Topcat series and the printers, the battery door is compatible between all specified models.
Sylvain
PS: lucky you if you have a HP-95C, which I do not, so for that model I am assuming that it will fit. (btw, there is a member of this forum who has one)
(09-12-2020 12:58 PM)Sylvain Cote Wrote: [ -> ]PS: lucky you if you have a HP-95C, which I do not, so for that model I am assuming that it will fit. (btw, there is a member of this forum who has one)
Lend it to Bernhard and we can get an emulator :-)
... a simulator so far
http://www.teenix.org/HP95C.zip
cheers
Tony
PS - Yay! I'm finally getting a teeny bit of internet of late.
(09-12-2020 12:58 PM)Sylvain Cote Wrote: [ -> ]...the battery door is compatible between all specified models.
Sylvain
I was pleased to recently find that not only is the entire door compatible, but on my HP 92, one of the door tabs broke, and even the door tabs can (carefully!) be removed from one door and put on another of the opposite color, e.g. from a more recent Printer or Tapedrive.
