08-28-2020, 02:18 AM
I'm in the process of migrating from the 48GX to the 50G, or at least trying to get my little programs moved over. What I realize I've done is I used the connectivity kit to transfer the directories and CST out of my 48GX to my PC, which is done in ASCII. When I open them with a text editor, this is what I see (for example, an incomplete copy of a directory, top level of which is "CHE"):
(Forgive the formatting, that's just how it comes out.)
When I copy it to the SD card and then insert the SD card into my 50G and then transfer it over to the HOME directory, what I transferred comes out as a string. Not a directory with subdirectories, equations, programs, etc. as it was on the 48GX.
So here are my questions:
%%HP: T(1)A(D)F(.);
DIR
EQ1 'Q/A=hc*(Tw-T
)+˜*“*(Tw^4-T^4)'
A '5.65895372234_
ft^2'
Q '90000_Btu/h'
U '112_Btu/(ft^2*
h*°F)'
dT '142_°F'
EQ { EQ1 HTX }
HTX 'Q=U*A*dT'
THERMO
DIR
EQULB
DIR
EQ '
1.06084841536E-2=4*
- Obviously I have to transfer these things from the 48GX in binary for them to work correctly in the 50G, right?
- I'd like to be able to edit these things on my computer. How can I transfer over, edit them, and then transfer them back?
