(06-14-2014 02:24 PM)Marcus von Cube Wrote: [ -> ]You should have checked out the complete tree.
I did try to checkout the code above the trunk few times in past, but my svn was against. Now it checkouts the complete tree, interesting (I've upgraded my svn, maybe that has helped).
I've changed the yagarto to 460 (
http://sourceforge.net/projects/yagarto/.../20110429/). Except the stuff with older make, I had to change the path to my yagarto in the makeflash.cmd, and to add the path to /tools into wp34s_asm.pl (at line 185, as recommended in a previous post). Also I work with complete tree now, so it finds the libs too..
Now I do not see any obvious error and the real build looks like (based on r3667):
Directory of D:\MyCode\Calculators\WP34s_2\code\trunk\realbuild
06/14/2014 16:55 <DIR> .
06/14/2014 16:55 <DIR> ..
06/14/2014 16:54 600,607 calc
06/14/2014 16:54 118,016 calc.bin
06/14/2014 16:54 183,552 calc.tmp
06/14/2014 16:55 121,344 calc_full.bin
06/14/2014 16:54 621,205 calc_ir
06/14/2014 16:55 123,136 calc_ir.bin
06/14/2014 16:55 188,672 calc_ir.tmp
06/14/2014 16:55 126,464 calc_ir_full.bin
06/14/2014 16:54 607,781 calc_xtal
06/14/2014 16:54 119,552 calc_xtal.bin
06/14/2014 16:54 185,088 calc_xtal.tmp
06/14/2014 16:55 122,880 calc_xtal_full.bin
06/14/2014 16:37 151 join.cmd
06/14/2014 16:54 113,295 mapfile.txt
06/14/2014 16:54 115,366 mapfile_ir.txt
06/14/2014 16:54 114,473 mapfile_xtal.txt
06/14/2014 16:37 414 README
06/14/2014 16:54 434 summary.txt
06/14/2014 16:55 434 summary_ir.txt
06/14/2014 16:54 434 summary_xtal.txt
06/14/2014 16:54 62,393 symbols.txt
06/14/2014 16:55 66,061 symbols_ir.txt
06/14/2014 16:54 63,960 symbols_xtal.txt
06/14/2014 16:55 3,328 wp34s-lib.dat
24 File(s) 3,659,040 bytes
2 Dir(s) 50,865,963,008 bytes free
The .bin sizes are not the same as the original ones, but maybe it will work.
The only warning I've found is something like:
// WARNING: Unrecognized O/S (msys). Some features may not work as expected.
in flash-build.log..
