07-03-2020, 01:44 PM
I would like have others verify this bug I have found in the DM42.
I am particularly interested if this bug exists in other versions of the OS (3.17, etc...)
I have some code that simply steps through (all 100) REG memories; recalling the memory location (in Y) and memory contents (in X).
This is a simple loop, terminated in ISG of the counter and jumps back to the recall and Pause (PSE) loop.
IF RefLCD is set to 0, the code stops before the PSE.
I do understand that RefLCD = 0 should not refresh the display, but this actually stops the code from executing.
I have posted this in the DM42 forum and it has been verified there; I am curious if it is sensitive to DM42 OS level.
When RefLCD is set to zero, this codes does not run; it stops after the PSE statement:
(it assumes that REGS is set to 100 - please adjust for your situation)
LBL RCLMEM
0.09901
STO "CTR"
LBL 03
RCL "CTR"
IP
RCL IND "CTR"
PSE
ISG "CTR"
GTO 03
RTN
TomC
LBL RCLMEM
0.09901
STO "CTR"
LBL 03
RCL "CTR"
IP
RCL IND "CTR"
PSE
ISG "CTR"
GTO 03
RTN
TomC
