06-27-2020, 01:35 PM
Converting to Binary
The program BASE2 can convert any real number in Base 10 to Base 2. This extends on the built in base conversions, which works on integers only. BASE2 returns a string with precision up to 23 bits. Negative numbers will have the negative sign instead of a 2's compliment.
HP Prime Program BASE2
Examples:
BASE2(18.675) returns "10010.101011001100110011"
BASE2(-4.3825) returns "-100.01100001111010111000"
BASE2(π) returns "11.001001000011111101101"
Converting to IEEE-754 Format
The program IEEE754 converts any real number in decimal base to binary in IEEE-754 floating point format. A binary number in this format consists of a string of 32 bits:
Bit 1 is the sign bit: 1 for negative numbers, 0 for positive numbers
The next eight bits is the exponent bit: The exponent bit has a bias of 127. When converting to binary, 127 must be added to the exponent. (Example: 17 * 2^3. The exponent bit is 127 + 3 = 130). When converting to decimal, subtract 127 from the exponent word.
The last 23 bits consist of the mantissa.
The function returns a string with spaces between the sign, exponent, and mantissa sections for readability.
HP Prime Program IEEE754
Example:
IEEE754(2100) returns "0 10001010 100000110100000000000000"
2100 -> 100000110100_2 -> 1.00000110100_2 * (2_10) ^ (11_10)
"moving the decimal point left 11 spaces"
Exponent bit: 127 + 11 = 138 (138_10 -> 10001010_2)
IEEE754(28.725) returns "0 10000011 11100101110011001100110"
IEEE754(-19.5) returns "1 10000011 10011100000000000000000"
Source:
Sivaraman, Abishalini. "Decimal to IEEE 754 Floating Pont Representation" YouTube Video Published December 4, 2016 https://www.youtube.com/watch?v=8afbTaA-...4_mdWQE84q
Petryk, Steve. "HOW TO: Convert Decimal to IEEE-754 Single-Precision Binary" YouTube Video. Published October 25, 2015. https://www.youtube.com/watch?v=tx-M_rqhuUA
Blog link: http://edspi31415.blogspot.com/2020/06/h...-ieee.html
EXPORT BASE2(s)
// 2020-05-18 EWS
// Decimal to Binary
// for real x
LOCAL str1,str2,str3;
LOCAL d,u,w,k,x;
x:=ABS(s);
// set Binary mode, integer
Base:=0;
str1:=STRING(R→B(IP(x)));
d:=DIM(str1);
str1:=MID(str1,2,d-2);
// fraction
w:=FP(x);
str2:=".";
FOR k FROM 1 TO 25-d DO
u:=IP(2*w);
w:=FP(2*w);
str2:=str2+STRING(u);
// answer
str3:=str1+str2;
IF SIGN(s)==−1 THEN
str3:="−"+str3;
RETURN str3;
Examples:
EXPORT IEEE754(s)
// 2020-05-19 EWS
// Decimal to IEEE 754 format
// for real x
LOCAL str1,str2,str3,str4,str5;
LOCAL d,u,w,k,x,p;
// determine sign bit
x:=ABS(s);
IF SIGN(s)==−1 THEN
str1:="1";
ELSE
str1:="0";
// set exponent
// account for 127 bias
// set Binary mode
Base:=0;
p:=127+IP(LOG(x)/LOG(2));
str2:=STRING(R→B(IP(p)));
d:=DIM(str2)-2;
str2:=MID(str2,2,d);
// fill 0s for p<127
IF d<8 THEN
FOR k FROM 1 TO 8-d DO
str2:="0"+str2;
// convert integer of mantissa
str3:=STRING(R→B(IP(x)));
d:=DIM(str3)-2;
// account for # and b
str3:=MID(str3,2,d);
// convert fraction of matissa
w:=FP(x);
str4:="";
FOR k FROM 1 TO 23-d DO
u:=IP(2*w);
w:=FP(2*w);
str4:=str4+STRING(u);
// answer
// add spaces for clarity
str5:=str1+" "+
str2+" "+
str3+str4;
// RETURN {str1,str2,str3,str4,str5};
RETURN str5;
Example:
Source:
