06-02-2014, 11:49 PM
Hi, I am able to repeat this issue on the Virtual Prime Emulator and the physical calculator, both that are update to the latest revision in firmware.
In CAS mode entering:
'(10+k)^.5=11/2 * 2^.5'
Then going to solve under the CAS menu and selecting the expression so that the line output looks like this:
solve('(10+k)^.5=11/2 * 2^.5',k)
The calculator and emulator reboots. I am able to repeat this.
If i do not include the quotes, then I am able to get the correct answer. I do not have k stored as a variable. I typically leave all my expression and equations in quotes out of habit, in case i did create a variable in a previous session.
Anyone have this problem or possible can see what i am doing wrong?
Thanks
Thanks
