09-08-2020, 05:32 PM
Richard: I used this program to convert a ROM dump into an intel hex file suitable for burning an EPROM. It is a one-off thing and has no error checking; it hasn't been cleaned up either, but it did the job for me.
/* dmp2hex.c : convert a nibble dump from the HP-71B DUMPROM BASIC program
into an intel HEX format file. Syntax is
$ dmp2hex infile.dmp > outfile.hex
The output is appropriate to burn an EPROM for the
Hand Held Products 71M/M EPROM carrier for the card reader slot.
A rom dump is just the nibbles in the Saturn cpu memory map
in order of increasing address (as returned by PEEK$), in the
form of a text file with 64 characters per line, each character
the ASCII hex digit {0-9, A-F} for each nibble.
But the data in the EPROM differs from this in that the most
significant nibble in each byte is the higher-addressed nible
in the memory map, and also in that the data is negated in the
ROM. Thus, a 16 nibble sequence in a ROM such as
B3DDDDDEE4642513
must be coded in the EPROM like these eight consecutive bytes
C4 22 22 12 B1 B9 AD CE DF
That is, C is the 1-complement of 3, 4 is the 1-complement of B,
2 is the 1-complement of the fourth nibble in the sequence (a D)
and so on.
Carlos E. Murillo-Sanchez 2020-06-15. Just a quick hack
without much error checking.
Version 1.0
#include <stdio.h>
#include <string.h>
unsigned char hex2nibble(unsigned char a)
{ unsigned char b;
if (a >= 48 & a <= 57) {
b = a - 48;
else if ( a >= 65 & a <= 70) {
b = a - 55;
else if ( a>= 97 & a <= 102 ) {
b = a - 87;
else {
fprintf(stderr, "Invalid ASCII character representation of hex value %s\n", a);
return b;
unsigned char nibble2hex(unsigned char a)
{ unsigned char b;
b = a & 0x0F;
if (b < 10) {
b = b + 0x30;
else
b = b + 55;
return b;
int
main (argc, argv, envp)
int argc;
char **argv;
char **envp;
char *ifile;
char *program;
FILE *fp;
unsigned char linein[66];
unsigned char nibbles[64];
unsigned char bytes[16];
unsigned char hexnibbles[64];
unsigned char hexbytes[64];
unsigned char tmpchar1, tmpchar2, tmpchar3, tmpchar4;
int lines, i, j, k;
program = strrchr (argv[0], '/');
if (argc < 2) {
printf("\nUsage: %s inputfile.dmp > outputfile.hex\n\n", program);
return 0;
fp = fopen(argv[1], "r");
if (fp == 0) {
printf("%s: Could not open %s file for input.\n", program, argv[1]);
return 1;
/*count the lines*/
lines = 0;
while (fscanf(fp, "%s", linein) == 1) {
if (strlen(linein) > 0) {
lines++;
fclose(fp);
/* do actual processing */
/* First write header of hex file */
printf(":020000040000FA\n");
/* Then write data */
k = 0;
/* Convert string of ascii hex values of nibbles into bytes */
for (i=0; i<64; i++) {
nibbles[i] = hex2nibble(linein[i]);
/* swap and complement every two nibbles */
for (i=0; i<32; i++) {
tmpchar1 = nibbles[2*i];
tmpchar2 = nibbles[2*i+1];
tmpchar1 = (~tmpchar1) & 0x0F;
tmpchar2 = (~tmpchar2) & 0x0F;
nibbles[2*i] = tmpchar2;
nibbles[2*i+1] = tmpchar1;
/* Convert to string of hex values */
hexbytes[i] = nibble2hex(nibbles[i]);
/* Output two lines of intel hex file format */
for (i=0; i<2; i++) {
printf(":10");
tmpchar1 = (unsigned char) ((16*k) & 0xFF);
tmpchar1 = tmpchar1 + (unsigned char) ( k / 16);
tmpchar1 = tmpchar1 + 16;
tmpchar2 = (unsigned char) ( k / 16 );
tmpchar3 = nibble2hex(tmpchar2 >> 4);
tmpchar4 = nibble2hex(tmpchar2);
printf("%c%c", tmpchar3, tmpchar4);
tmpchar2 = (unsigned char) ((16*k) & 0xFF);
printf("00");
for (j=0; j<16; j++) {
printf("%c%c", hexbytes[32*i+2*j], hexbytes[32*i+2*j+1]);
tmpchar2 = 16*nibbles[32*i+2*j] + nibbles[32*i+2*j+1];
tmpchar1 = tmpchar1 + tmpchar2;
tmpchar1 = ~tmpchar1 + 1;
tmpchar2 = tmpchar1 >> 4;
printf("%c%c\n", nibble2hex(tmpchar2), nibble2hex(tmpchar1));
k++;
printf(":00000001FF\n");
fclose(fp);
return 0;
B3DDDDDEE4642513
and so on.
Version 1.0
#include <stdio.h>
#include <string.h>
{ unsigned char b;
b = a - 48;
b = a - 55;
b = a - 87;
else {
return b;
{ unsigned char b;
b = a & 0x0F;
if (b < 10) {
b = b + 0x30;
else
b = b + 55;
return b;
int
int argc;
char **argv;
char **envp;
char *ifile;
char *program;
FILE *fp;
int lines, i, j, k;
if (argc < 2) {
return 0;
if (fp == 0) {
return 1;
/*count the lines*/
lines = 0;
lines++;
fclose(fp);
k = 0;
printf(":10");
printf("00");
k++;
fclose(fp);
return 0;
