Summation of (1/x^3) from x=1 to infinity produces Zeta(3) which is correct, ~1.20206. Why does summation of (1/x^2) from x=1 to infinity produce +/- infinity on my G2? For that matter the summation for 1/x^odd integer produces correct results, incorrect for (1/x^even integer). A summation of (1/x^p) should converge for any p>1.
In home, the summations (1/x^even integer from 1 to infinity) are approximated correctly...why is there a difficulty in CAS?
My G2 also gives, in the CAS, a finite result for 1/x^2, i.e., (pi^2)/6. Anyway, my firmware is not the most recent: 2.0.0.13865 (2018 08 02), so I have to update it.
(06-10-2020 12:20 PM)ramon_ea1gth Wrote: [ -> ]My G2 also gives, in the CAS, a finite result for 1/x^2, i.e., (pi^2)/6. Anyway, my firmware is not the most recent: 2.0.0.13865 (2018 08 02), so I have to update it.
Same result for me in the emulator [2.1.14425 (2020 1 16)], and also my G2 [2.1.14433 (2020 01 21)]
(06-10-2020 02:16 AM)lrdheat Wrote: [ -> ]Summation of (1/x^3) from x=1 to infinity produces Zeta(3) which is correct, ~1.20206. Why does summation of (1/x^2) from x=1 to infinity produce +/- infinity on my G2? For that matter the summation for 1/x^odd integer produces correct results, incorrect for (1/x^even integer). A summation of (1/x^p) should converge for any p>1.
Seeing the above answers you should give us the command line you used.
Mine are:
Home:
approx(Σ(1/X^2,X,1,∞))
CAS:
When I use the template in CAS, it comes up with +/- infinity if a small “x” is used (as is default in CAS). If I use capital “X” in CAS, I just discovered that the correct pi^2/6 comes up for summation 1/X^2 from 1 to infinity. Why is this, and do I have some setting incorrectly set to produce this odd behavior?
try to delete all values and assumptions of x:
Thanks...that worked. I did not suspect this was the problem since the series worked for odd powers!
In general, if you want to see/check user variables:
created in Home, := or Sto▸
- viewed with memory manager Shift B — User Variables
- select, then delete or backspace
created in CAS, = or Sto▸
- viewed with memory manager Shift B — CAS Vars
- may also be deleted with CAS function purge(), which only works on CAS vars
- purge() also removes assumptions about vars, as well as value
A couple of CAS programs have been posted on this forum in the past:
varslist()
- shows all defined lowercase single letter vars, both Home & CAS
purgeaz()
- purges all single small-letter CAS variables, excluding e & i which are reserved
- does not affect Home variables, which can only be deleted using memory manager (shift B)
(06-11-2020 02:36 PM)lrdheat Wrote: [ -> ]Thanks...that worked. I did not suspect this was the problem since the series worked for odd powers!
Maybe x was assumed to be negative.
