05-31-2020, 02:07 PM
Here are three examples on how Horner's Method can be used to quickly calculate rational fractions with polynomials. The program code is presented for the HP 12C.
Horner's rule involves repeated factoring until the polynomial is represented as a multiplication of polynomials. The idea is to make it easier for some scientific calculators and four-function calculators to evaluate polynomials. Using Horner's Method for the generic cubic polynomial:
a * t^3 + b * t^2 + c * t + d
t * (a * t^2 + b * t + c) + d
t * (t * (a * t + b) + c ) + d
On an RPN keystroke calculator, such as the HP 12C a possible code would look like:
STO t (from the X stack)
RCL a
RCL b
RCL t
RCL c
RCL t
RCL d
RTN
For the code below, the HP 12C uses the following registers:
R0 = x
R1 = a
R2 = b
R3 = c
R4 = d
R5 = e
R6 = f
R7 = g
All but x need to be stored ahead of time before running (you can change the code to suit your needs, of course). x is entered before pressing [ R/S ].
For all of our numerical examples, I assigned the following values:
R0 = 1.72
R1 = 6
R2 = 3
R3 = 4
R4 = 5
R5 = 3
R6 = 1
R7 = 8
Example 1
(ax + b) / (cx^2 + dx + e) = (ax + b) / (x * (cx + d) + e)
Program (key: key code) - 16 steps
Result with variables stored above (FIX 4): 0.5684
Example 2
(ax + b) / (cx^3 + dx^ 2 + ex + f) = (ax + b) / (x * (x * (cx + d) + e) + f)
Program (key: key code) - 20 steps
Result with variables stored above (FIX 4): 0.3225
Example 3
(ax^2 + bx + c) / (dx^3 + ex^2 + fx + g)
= (x * (ax + b) + c) / (x * (x * (dx + e) + f) + g)
Program (key: key code) - 24 steps
Result with variables stored above (FIX 4): 0.6111
Blog Entry: http://edspi31415.blogspot.com/2020/05/h...rners.html
RCL a
RCL b
RCL t
RCL c
RCL t
RCL d
RTN
R0 = x
R1 = a
R2 = b
R3 = c
R4 = d
R5 = e
R6 = f
R7 = g
R0 = 1.72
R1 = 6
R2 = 3
R3 = 4
R4 = 5
R5 = 3
R6 = 1
R7 = 8
Example 1
STO 0: 44, 0
RCL 1: 45,1
* : 20
RCL 2: 45, 2
+ : 40
RCL 0: 45, 0
RCL 3: 45, 3
* : 20
RCL 4: 45, 4
+ : 40
RCL 0: 45, 0
* : 20
RCL 5: 45, 5
+ : 40
÷ : 10
GTO 00: 43, 33, 00
Example 2
STO 0: 44, 0
RCL 1: 45,1
* : 20
RCL 2: 45, 2
+ : 40
RCL 0: 45, 0
RCL 3: 45, 3
* : 20
RCL 4: 45, 4
+ : 40
RCL 0: 45, 0
* : 20
RCL 5: 45, 5
+ : 40
RCL 0: 45, 0
* : 20
RCL 6: 45, 6
+ : 40
÷ : 10
GTO 00: 43, 33, 00
Example 3
STO 0: 44, 0
RCL 1: 45,1
* : 20
RCL 2: 45, 2
+ : 40
RCL 0: 45, 0
RCL 3: 45, 3
* : 20
RCL 4: 45, 4
+ : 40
RCL 0: 45, 0
* : 20
RCL 5: 45, 5
+ : 40
RCL 0: 45, 0
* : 20
RCL 6: 45, 6
+ : 40
RCL 0: 45, 0
* : 20
RCL 7: 45, 7
+ : 40
÷ : 10
GTO 00: 43, 33, 00
