I'm not sure if this is legal to do but it shouldn't crash the calculator. I was trying to find the area of the space between a triangle and a circle contained within the triangle.
attachment=729]
attachment=731]
From the Num entry I tried:
attachment=730]
And when I pressed Enter, the Calculator rebooted and the Geometry App reverted to a previous session.
(06-01-2014 02:45 PM)ndzied1 Wrote: [ -> ]And when I pressed Enter, the Calculator rebooted and the Geometry App reverted to a previous session.
I can reproduce this crash as well. However, are you not really looking for area(GA) - area(GB)? The Geometry App produces the correct results using this syntax.
Mark Hardman
Yes, I was really looking for area(GA) - area(GB) as you state but typed in the other by mistake and the prime re-booted. The area(GA) - area(GB) does work.
My real goal was to shade the area between the objects and display the area but I haven't found a way to do that yet.
(06-01-2014 02:59 PM)ndzied1 Wrote: [ -> ]Yes, I was really looking for area(GA) - area(GB) as you state but typed in the other by mistake and the prime re-booted. The area(GA) - area(GB) does work.
From the Plot view, select the triangle and use Options/Fill to set its fill color. Select the circle, use Options/Choose Color.. to change the color to white and the select Options/Fill.
You can also set any closed object's fill color in the Geometry Symbolic View by double-clicking on the color selection square.
I've just tried doing the same with the emulator (latest version: rev. 6031) and... guess what?
Yes! It also ends with an
epic crash!
The evidence:
If I create a triangle with a circle inside...
And then try to enter the formula as suggested...
KABOOM!
I know this is not the way to calculate the area difference... but it's just a bit fun to see how this badly hurts both the calc and the emulator.
I wonder what the inner workings are that would lead to a crash, instead of a "Syntax Error", or whatever...
