05-24-2020, 12:30 AM
According to https://www.swissmicros.com/voyager/firm...istory.txt, "V30 firmware was removed after confirmation of excessive consumption in OFF mode, Everybody should revert to V29 firmware."
I just did but that was not easy, it took me several times before the update tool recognised the device and flashed it. I used a mini-USB cable I had lying around from an old phone, are the SwissMicros calculators so sensitive to which calbe you use? They sell a shielded one, would that matter much?
