05-17-2020, 06:45 PM
It's normal a delay turning on the calculator with a HP IL module plugged in? I mean that the display sometimes takes a few second before to show the content of the X register.
LBL "TSTIL"
LBL 01
AVIEW
TONE 0
GTO 01
END
(05-17-2020 07:19 PM)Sylvain Cote Wrote: [ -> ]Normal delay when the loop is broken or when a device on the loop is powered off.
If you have no device connected, connect the two cable end together so the loop is closed.
Edit: Didier beat me to it.
(05-17-2020 08:04 PM)Sylvain Cote Wrote: [ -> ]Check that the module contacts are clean and that they do connect correctly with the flex.for "close loop" you mean shortening the connectors of the module?
You may have a defective cable, a way to test this is to enter the following program and run it with a close loop.
Play with the cable to see if the tone stop or the beep interval becomes very long, if it is the case then you may have a semi-broken cable.
LBL "TSTIL"
LBL 01
AVIEW
TONE 0
GTO 01
END
(05-17-2020 08:04 PM)Sylvain Cote Wrote: [ -> ]Check that the module contacts are clean and that they do connect correctly with the flex.Thank-you, Sylvain, performed the test, it seems the cable is OK on the module, I checked the second cable making the loop on the connector of the PILBOX with the same positiveresult .
LBL "TSTIL"
LBL 01
AVIEW
TONE 0
GTO 01
END
(05-17-2020 08:14 PM)aurelio Wrote: [ -> ](05-17-2020 07:19 PM)Sylvain Cote Wrote: [ -> ]Normal delay when the loop is broken or when a device on the loop is powered off.
Now I have the controller (HP41) + HPIL module + PILBOX connected to a PC, no emulators, and the calculator turns on regularly, it means that just the phisical loop must be closed ?
I got, last time, the problem leaving the calculator connected to the PC after a session of the PYIlPER, and turning it on
(05-18-2020 08:00 AM)J-F Garnier Wrote: [ -> ]Thank-you, J-F, It means if I understood that the first test to do (with the Sylvain's program) is the integrity of the whole phisical loop with the PILBOX connected to the PC (this way USB powered), without any emulator, then if there is a failure, I can look eventually for any issue related to the cables, reducing each time the lenght of the loop.(05-17-2020 08:14 PM)aurelio Wrote: [ -> ]Now I have the controller (HP41) + HPIL module + PILBOX connected to a PC, no emulators, and the calculator turns on regularly, it means that just the phisical loop must be closed ?
With the PIL-Box, a "closed loop" has a slightly different meaning.
When the PIL-Box is powered up, it justs re-transmits the HP-IL traffic to the controller (the 41C), so the loop is closed.
But when an application on PC initializes the PIL-Box, the PIL-Box starts to re-transmit the HP-IL traffic to the PC. If the application doesn't reply for some reason, the loop is "broken".
With the regular ILPer, the PIL-Box is put back to simple re-transmission on HP-IL side when the application terminates, so the loop is still "closed" when the application has ended. I don't know for pyILPER.
J-F
