04-30-2020, 08:45 PM
This time, it's a function for the HP17BII to search Mastermind code
I think my formula needs to be modify to run on the HP17BII+ because i use some multiply by 0
But it could run on HP27S too
The formula is close to the mechanism in use for the program running on the 12C
You should see the 3 steps :
1) generates the code to break (MIND) when N is 0
2) search for black positions between MIND and N (the user attempt) and prepares the white step
3) search for white positions among the remaining non black positions
There is the code :
Example of use :
[CALC] → [EVAL] [ N ] [ NIVO ] [ RAN# ] [ MIND ] [ NB ]
DSP [ FIX ] 2 INPUT
,123456789 [RAN#]
5 [NIVO]
0 [N]
[EVAL] → EVAL=0,00
12399 [N] [EVAL] → EVAL=12399,05 : 0 black position but 5 white positions
99321 [N] [EVAL] → EVAL=99321,32 : 3 black positions and 2 white positions
93921 [N] [EVAL] → EVAL=93921,50 : all 5 positions found
RCL [NB] → NB=3,00 after 3 attempts
0 [N]
[EVAL] → EVAL=0,00
xxxxx [N] [EVAL] and so on
There is the code :
EVAL =
IF( N=0 :
L( MIND : Σ ( I : 1 : NIVO : 1 : ALOG( I – 1 ) x INT( 1 + 9 x
L( RAN# : IF( FP( RAN# ) = 0 : ,5284163 : FP( RAN# x 997 ) ) ) ) ) ) x L( NB : 0) :
L( TV : N ) x 0 + L( MD : MIND ) x 0 + L( NB : NB + 1 ) x 0 + L( TW : 0 ) + L ( MW : 0 ) +
N +
,1 x ( Σ ( I : 1 : NIVO : 1 :
IF( L( TI : INT( 10 x FP( G( TV ) ÷ L( DV : ALOG( I ) ) ) ) ) =
L( MI : INT( 10 x FP( G( MD ) ÷ G( DV ) ) ) ) : 1 :
L( TW : G( TW ) + ALOG( G( TI ) - 1 ) ) x 0 +
L( MW : G( MW ) + ALOG( G( MI ) - 1 ) ) x 0 ) ) ) +
,01 x ( Σ ( I : 1 : 9 : 1 :
MIN( INT( 10 x FP( G( TW ) ÷ L( DV : ALOG( I ) ) ) ) :
INT( 10 x FP( G( MW ) ÷ G( DV ) ) ) ) ) )
Example of use :
DSP [ FIX ] 2 INPUT
,123456789 [RAN#]
5 [NIVO]
0 [N]
[EVAL] → EVAL=0,00
0 [N]
[EVAL] → EVAL=0,00
