04-14-2020, 01:19 PM
DIM: (Syntax: rows, cols, DIM) Sets the initial dimensions of the matrix.
INDEX: Sets the index pointer to I = 1 and J = 1.
GROW: Sets the HP 42S to grow mode. This allows the matrix to build additional rows and columns by adding new elements.
J+: Does one of two things in Grow Mode. It either moves the pointer to the next column or creates a new row. For a matrix with only 1 column as its initial dimension, J+ creates a new row automatically.
Matrix: 1 to N
The first program, nLIST generates a one column matrix from 1 to n.
LBL 00: Main Loop
LBL 01: Adds another row
LBL 02: End of program and shows the resulting matrix, MATD in edit mode
R01: counter variable counting from n (in X stack) to 1
HP 42S/Free 42S/DM42 Program: nLIST
Example: 8 nLIST returns
[[ 8 ]
[ 7 ]
[ 6 ]
[ 5 ]
[ 4 ]
[ 3 ]
[ 2 ]
[ 1 ]]
Press the soft keys ( ↑ ) and ( ↓ ) to scroll throw the matrix. Press [EXIT] to exit the matrix. The matrix MATD is stored as a stack element.
Simulating HP Prime's idivis Command
The program IDIVIS simulates the IDIVIS command on the HP Prime. IDIVIS lists all the divisors of an integer ( n ).
LBL 00: Main Loop - tests for divisors
LBL 01: Adds any divisors and creates another row
LBL 02: Decreases the counter variable
LBL 03: Trims the excessive row by the DELR (delete row) command, ends the program and shows the resulting matrix, MATD in edit mode
R00: n
R01: counter variable counting from n (in X stack) to 1. The program stops when R01 reaches 0 (it is skipped thanks to the DSE command).
R02 = R00/R01
HP 42S/Free 42S/DM42S Program: IDIVIS
Examples
45 (IDIVIS) returns 1, 3, 5, 9, 15, 45 (press ↓ to reveal the next row in MATD)
27 (IDIVIS) returns 1, 3, 9, 27
53 (IDIVIS) returns 1, 53
Matrix: 1 to N
LBL 00: Main Loop
00 { 50-Byte Prgm }
01▸LBL "nLIST"
02 STO 01
03 1
04 1
05 DIM "MATD"
06 INDEX "MATD"
07 GROW
08▸LBL 00
09 RCL 01
10 STOEL
11 DSE 01
12 GTO 01
13 GTO 02
14▸LBL 01
15 J+
16 GTO 00
17▸LBL 02
18 EDITN "MATD"
19 END
[[ 8 ]
[ 7 ]
[ 6 ]
[ 5 ]
[ 4 ]
[ 3 ]
[ 2 ]
[ 1 ]]
R00: n
R02 = R00/R01
00 { 64-Byte Prgm }
01▸LBL "IDIVIS"
02 STO 00
03 STO 01
04 1
05 1
06 DIM "MATD"
07 INDEX "MATD"
08 GROW
09▸LBL 00
10 RCL 00
11 RCL÷ 01
12 STO 02
13 FP
14 X=0?
15 GTO 01
16 GTO 02
17▸LBL 01
18 RCL 02
19 STOEL
20 J+
21▸LBL 02
22 DSE 01
23 GTO 00
24 GTO 03
25▸LBL 03
26 DELR
27 EDITN "MATD"
28 .END.
Examples
