04-12-2020, 06:26 AM
HP provided the Emulator for HP-12C, HP-12C Platinum and HP-15C
These emulator when view in vertical orientation mode you will get
a basic calculator and only the exception is the HP-12C Platinum where
you get the "Tip Calculator" function. Others doesn't have even the percent
key in verticle mode. I noticed that to calculate percent is an easy task.
For example: 100 + 10% = 110 and the percent amount is 10
Keystroks steps are 100 [ENTER] [ENTER] .1 [x] display 10 [+] display 110
Since HP-12C Platinum got the Tip Calculator function this can be use for
adding tax or discount percent problem same as using the Percent function.
For example: RPN mode
Keystroks steps: Default input at Split key: 1 g [Split]
100 g [Bill] display 100.00
10 g [Tip%] display 10.00
g [Tip] display answer 10.00
g [Total] display answer 110.00
If you need to calculate discount percent using above example
[RCL] g [Bill] display 100.00
[RCL] g [Tip] display 10.00
[-] display answer 90.00
Remark:
Since 1 is input to [Split] as default any other input and output
can be use to calculate percent addition and percent subtraction problems.
This will be a very handy calculator app in vertical mode when you
need to use only one hand on the go calculations.
[RCL] g [Bill]
[RCL] g [Tip%]
[RCL] g [Split]
[RCL] g [Tip]
[RCL] g [Total]
Five variables above can be use as a Store Registers
Gamo
Remark:
[RCL] g [Bill]
[RCL] g [Tip%]
[RCL] g [Split]
[RCL] g [Tip]
[RCL] g [Total]
Gamo
