I bought the HP Prime about 1 week ago. I have used it daily. I have worked with it and shut it down many times. Today I did a factory reset using CFO and reset on back, format and reset option. Everything seemed to work great. Calculator is working fine. Until I noticed:
I shut it down and it came back on within 2 seconds.
I let it sit until it dimmed, then it shut down on its own, then came back on within 2 seconds.
This is definitely odd behavior. Has anyone here had this issue? What should I do?
Have you tried the pin hole reset?
Maybe there is some kind of foreign matter stuck in the on key. In which case it may be a warranty issue, and you might contact hp support for guidance.
-Dale-
(04-08-2020 06:01 PM)AcoustricBruce Wrote: [ -> ]I bought the HP Prime about 1 week ago. I have used it daily. I have worked with it and shut it down many times. Today I did a factory reset using CFO and reset on back, format and reset option. Everything seemed to work great. Calculator is working fine. Until I noticed:
If your Prime is a G2, then it's a known bug in some firmware versions. This "Won't Stay Off" mode can be intentionally
started by unplugging the USB cable (if any) and then exiting the C+F+O diagnostic screen by pressing 9.
There are several ways to revive your G2's ability to turn off normally:
Method #1: Enter Coma Mode (hold down Shift, then press and hold On for one second, then release both), then power back up.
Method #2: Exit C+F+O diagnostic screen by pressing the C key (not the 9 key as usual).
Method #3: With Prime plugged into a powered USB cable, turn Prime off and back on, twice.
(04-09-2020 12:50 PM)Joe Horn Wrote: [ -> ]Method #3: With Prime plugged into a powered USB cable, turn Prime off and back on, twice.
Method #3 is hilarious!
I had to check the calendar to be sure it wasn't April 1st...
Is it really twice or will any even number do?
(04-09-2020 11:42 PM)rprosperi Wrote: [ -> ] (04-09-2020 12:50 PM)Joe Horn Wrote: [ -> ]Method #3: With Prime plugged into a powered USB cable, turn Prime off and back on, twice.
Strange but true. Twice returns Prime to normal, so any subsequent power cycling has no effect on that bug.
