My recently acquired 33C works great except the SST key does not work at all. The key can be pressed normally and "clicks" as it should but it does nothing. This prevents me from reviewing programs (SST/BST) and changing the decimal display (FIX).
I am very reluctant to open the calculator as the Spice case is very brittle and the screw posts break very easily (ask me how I know).
Except for this the calculator in in great shape but I'd love to have it work as it should.
Any ideas?
(03-23-2020 10:24 AM)Moggul Wrote: [ -> ]My recently acquired 33C works great except the SST key does not work at all. The key can be pressed normally and "clicks" as it should but it does nothing. This prevents me from reviewing programs (SST/BST) and changing the decimal display (FIX).
Any ideas?
Hi Moggul, may I know please if, performing the selftest, you get an error message ?
If you break the posts (I hope not so), it'easyer, anyway, to fix them and of course you should not worry, at least, to compromise the calculator's functionality like it could happen with other machines (41), don't be scared of that... maybe the contact of that key is just dirty and just needs to be cleaned...
(03-23-2020 06:25 PM)aurelio Wrote: [ -> ]Hi Moggul, may I know please if, performing the selftest, you get an error message ?
Thank you Aurelio.
The self test comes as full 8's and the calculator operates normally.
I have opened a couple of 32Es and the posts are very brittle so I am quite reluctant to open this fine unit. Also when opened, series 3 machines tend to show display errors as the LCD contacts come a bit loose.
(03-24-2020 08:48 AM)Moggul Wrote: [ -> ]Thank you Aurelio.
thank you for the feedback, it seems to be a mechanical/contact issue. I've not other advices, you should check inside, I guess, under the keyboard, although I understand your reluctance in opening the calculator: if not absolutely required I never do it.
I opened in past times some of those spices with soldered and un soldered component, to solve problems due to ribbon corroded by batteries' leakage, once only successfully, but you won't believe me.. I've been always very lucky with posts and screws.
If you had a mint calculator, I mean cosmetically very nice, but defective, would you swap it with a worn one, full of scrapes but perfectly working?
This is the question...
Also for this reason sometimes collectors own duplicates
