03-22-2020, 09:40 PM
This article is trying to explain how each HP-41C bank switching peripherals & modules works.
After reading bank switched capable devices documentation and with the help of our devices/mcode guru: Monte, Diego, Meindert, Ángel, Håkan, etc., I have gathered the following information.
This is a work in progress, missing devices will be added as I finish reading manuals and get confirmation of my understanding from the devices creators when possible.
Sylvain
CMT-10-16KB packaged in a module shell:
RAM bank switching behavior:
MLDL2000 packaged in a card reader shell:
edit: typo
Sylvain
- unit specifications:
- released in September 1985
- uses a 27C256 EPROM (256k bits = 16k x 16 bits words)
- splitted into four 4K (x16 bits) blocks (0 to 3)
- extended 16 bits NUT instruction structure:
- bits 15 to 13 must be set to zero
- bits 12 to 10 are for blocks switching
- bit 12 set to 1 indicate to the module internal firmware/hardware to interpret bits 11 and 10
- bits 11 & 10 indicate the following: 00 = block 0, 01 = block 1, 10 = block 2, 11 = block 3
- bits 9 to 0 are for NUT instructions
- bank switching can also be done with 16 bits modified ENBANKx/ENROMx instructions:
- ENBANK1/ENROM1: 0x100 or 01 0000 0000 becomes 0001 0101 0000 0000 or 0x1500
- ENBANK2/ENROM2: 0x180 or 01 1000 0000 becomes 0001 1001 1000 0000 or 0x1980
- ENBANK3/ENROM3: 0x140 or 01 0100 0000 becomes 0001 1101 0100 0000 or 0x1D40 (not in the manual but can be extrapolated)
- ENBANK4/ENROM4: 0x1C0 or 01 1100 0000 (not in the manual and not supported)
- bank switching behavior:
- bank 1 even/lower page always contains 4K block 0
- bank 1 odd/higher page often contains 4K block 1 (at boot up, mode changes, etc)
- bank 1 odd/higher page is changed to the specified block (0 to 3) when the module encounter an instruction with block switching bits set
- bank 1 odd/higher page is changed to the specified block (1 to 3) when a modified ENBANK1 to ENBANK3 instruction is interpreted
- released in 1987
- 16K EPROM (not specified but probably uses a 256k bits EPROM like the 27C256)
- can be configured as 16K flat or as two banks of 8K
- bank switching instructions:
- ENBANK1/ENROM1 and ENBANK2/ENROM2 are supported (0x100, 0x180)
- ENBANK3/ENROM3 and ENBANK4/ENROM4 are not supported (0x140, 0x1C0)
- ENBANK1/ENROM1 activate the first 8K (even/odd pages)
- ENBANK2/ENROM2 activate the second 8K (even/odd pages)
- units specifications:
- Clonix 41 module was released in December 2003
- Clonix 41: 24K Flash
- Clonix-D: 48K Flash
- USB-41: 48K Flash (82143A emulation on Windows over USB)
- NoVRAM: 16K FRAM & 24K Flash (8K Flash available)
- NoV-32: 32K FRAM & 24K Flash (8K Flash available)
- NoV-64: 64K FRAM & 48K Flash (32K Flash available)
- NoV-64d: 64K FRAM & 48K Flash (32K Flash available)
- Flash bank switching instructions:
- ENBANKx/ENROMx 1 to 4 are supported (0x100, 0x180, 0x140, 0x1C0)
- page & bank mapping is done with ClonixConfig Windows utility
- a non-bank switch ROM image is mapped to all the other banks of the same page
ex.: the MATH ROM is mapped to banks 1, 2, 3 & 4 of the page it is mapped to - bank switch ROM image is mapped to all the other banks according to the bank switch behavior (2 banks or 4 banks scheme)
- a 2 banks scheme ROM will map bank 1 to bank 1 & 3 and map bank 2 to bank 2 & 4.
ex: Advantage ROM even page is mapped to banks 1, 2, 3 & 4
ex: Advantage ROM odd page bank 1 is mapped to banks 1 and 3
ex: Advantage ROM odd page bank 2 is mapped to banks 2 and 4 - a 4 banks scheme ROM will map each banks to their expected locations (B1>B1, B2>B2, B3>B3, B4>B4).
- Flash bank switching behavior:
- a bank switch in Clonix/NoV module switch all pages of that module to the selected bank
ex.: ENBANK3/ENROM3 executed in a Clonix/NoV module activate bank 3 for all pages (from 0x4 to 0xF at the same time) for that module
- RAM bank switching instructions:
upcoming
upcoming
- released in June 2005
- SRAM: 512K x 16 bits (s/n >= 2050)
- SRAM: 1M x 16 bits (s/n < 2050)
- Flash: 1M x 16 bits (Flash can contain up to 255 ROM images)
- firmware v1.51: support bank switching from page 0x6 to page 0xF
- firmware v1.70: support bank switching from page 0x0 to page 0xF
- Bank switching behavior:
- even/odd pages are linked (0x6/0x7, 0x8/0x9, 0xA/0xB, 0xC/0xD, 0xE/0xF)
- lower pages bank switching (0x0 to 0x5) is not explained
- beta board was released in November 2011
- 41CL v2: 512 KB SRAM & 2 MB Flash (Flash can contain up to 256 ROM images)
- 41CL v3: 1 MB SRAM & 4 MB Flash (Flash can contain up to 512 ROM images)
- 41CL v4: 1 MB SRAM & 4 MB Flash (Flash can contain up to 512 ROM images)
- 41CL v5: 1 MB SRAM & 8 MB Flash (Flash can contain up to 1024 ROM images)
- bits 15 to 14 unused (reserved, currently ignored)
- bits 13 to 12 used for turbo handling (bits = this/next instruction)
- 00 = turbo execute / turbo fetch (if enabled)
- 01 = normal execute / normal fetch
- 1x = refetch, normal execute / normal fetch
- bits 11 to 10 unused (reserved, currently ignored)
- page & bank mapping are done with the WCMD NEWT instruction (0x1FC) and with the MMU (0x804xxx adresses)
- OS pages are not bank switch enabled (0x0, 0x1, 0x2, 0x3)
- some lower pages are standalone (0x4, 0x6, 0x7)
- pages 0x3/0x5 are linked, but only 0x5 is actually bank switched
- even/odd port pages are linked (0x8/0x9, 0xA/0xB, 0xC/0xD, 0xE/0xF)
- each standalone page or linked pages are bank switched independently from each other
- all bank selects are returned to select Bank 1 when entering Deep Sleep because the FPGA is powered down when the calculator is off.
upcoming
upcoming
edit: typo
