I use domain() function to find the domain of function Sqrt(x^2-9)/(x-3)
The calculator returns result [x<=-3 x>=3 and x <>3]
When simplify, it is expected to have [x<=-3 x>3], but the calculator returns result [x<=-3 x>=3]
How can we have correct simplified answer?
The bug probably not from simplify, but x≠3
XCas> purge(x)
XCas> x >= 3 // returns x ≥ 3, as expected
XCas> x != 3 // returns true ???
XCas> [(x <= -3), (x >= 3) and (x != 3)] // dropped "and true", returns [x <= -3, x >= 3]
It's unfortunately unavoidable. x!=3 will return true, because in this test x is considered to be a variable, and a variable is not the same as an integer.
I see. So the calculator treats x>=3, x<>3 as logical comparison rather than a set of number.
Any representation of the set x>=3?
There is an internal representation, used by assume/about, but no user commands.
A new command to graph interval is very important, for example to graph the solution [x≤-3, (x≥3) AND (x≠3)] the following instruction is required
F1(X):=PIECEWISE( X≤-3, 0, (X≥3) AND (X≠3), 0 ) [enter] [plot]
(03-03-2020 06:06 AM)parisse Wrote: [ -> ]There is an internal representation, used by assume/about, but no user commands.
Any way of adding an exported command or function?
Would it be useful in the described cases?
VPN
No, there is no support for the internal representation of assume in user commands.
(03-04-2020 08:10 PM)parisse Wrote: [ -> ]No, there is no support for the internal representation of assume in user commands.
I know there isn't at the moment
but
would it be useful
if you would ADD such a support?
Is it possible to add new keywords?
like this: "set { x<3 x>3 }"
VPN
There is nothing planned. I have myself no idea how to handle properly these kinds of objects.
(03-05-2020 06:31 AM)parisse Wrote: [ -> ]There is nothing planned. I have myself no idea how to handle properly these kinds of objects.
okay
Users just have to careful and
also know – not just the math
but also the limitations of their tools.
VPN
