01-29-2020, 06:09 PM
I found that my oldest HP-41 case leaves a powdery residue on the calculator. Are there any suitable replacements for it? Preferably one that fits an HP-41 without a card reader.
(01-29-2020 06:34 PM)Jurgen Keller Wrote: [ -> ]The powdery residue comes from the black lining inside the case. Put the cases into the washing machine and choose a "soft" program. You may even turn the inside out to get better results. That usually solves the problem.
(01-29-2020 07:41 PM)Massimo Gnerucci Wrote: [ -> ](01-29-2020 06:34 PM)Jurgen Keller Wrote: [ -> ]The powdery residue comes from the black lining inside the case. Put the cases into the washing machine and choose a "soft" program. You may even turn the inside out to get better results. That usually solves the problem.
Yes, that's how to solve this problem.
(01-29-2020 08:45 PM)smp Wrote: [ -> ]Inexpensively available, as opposed to trying to acquire an original HP-41 case:
https://www.ebay.com/itm/HP-Zipper-Case-...SwlThcO5yV
(01-30-2020 12:01 AM)Sylvain Cote Wrote: [ -> ]When I do not use the card reader, I found that the Spice/Spike cases are perfect for the HP-41C, also, they do not degrade like the original case.
(01-30-2020 12:31 AM)rprosperi Wrote: [ -> ]absolutely agree with Sylvain and with Bob, the larger/padded Spice's case fit perfectly and safely for the 41 c/readerless, and better slips into a suitcase/briefcase when you travel(01-30-2020 12:01 AM)Sylvain Cote Wrote: [ -> ]When I do not use the card reader, I found that the Spice/Spike cases are perfect for the HP-41C, also, they do not degrade like the original case.
Good point, my suggestion above only applies for a 41 w/o card reader.
As for Spice cases, I never tried that before now; nice idea
I found the 41 fits perfectly in the larger/padded style Spice/Spike cases, but not really in the smaller/un-padded style. The latter style is too tight, and also, un-padded, which IMHO is too dangerous for carrying a 41; one drop in that and it will likely cost you post damage.
(01-31-2020 01:55 AM)mfleming Wrote: [ -> ]Probably worth mentioning that Samson Cables carries their own line of calculator cases for various HP series, including the 41, 48, and Pioneer series. You can find them on their website or on TAS. I have several for the 41's I acquired without cases. They have a decent amount of padding and include a belt loop if you really want to go retro. No engineering student in the 70's was without one!
(01-31-2020 05:23 PM)hth Wrote: [ -> ]That leather field case looks interesting, though it fits the card reader. There is also a case for Woodstock/Nut, but only available in maroon at the moment. Which one did you get?
The comments about other cases made me look in my drawer for my unrestored HP-67 which has a nice well padded case, though it is a bit thick to accompany magnetic cards and quick reference cards. It seems like a good fit for the HP-41, I will borrow that for a while from the HP-67.
(07-31-2021 08:51 AM)floppy Wrote: [ -> ]I ordered my alternative case. I am happy.
https://www.etsy.com/listing/1053133635/...ve_1&frs=1
(07-31-2021 01:55 PM)aurelio Wrote: [ -> ]Just ask the seller if and when he can sell the same to you.(07-31-2021 08:51 AM)floppy Wrote: [ -> ]I ordered my alternative case. I am happy.
Hi, nice case, but maybe just one piece was available
(01-30-2020 07:03 PM)Jurgen Keller Wrote: [ -> ]If you mean the dark brown zipper case with very long zipper, then yes, that case,(01-30-2020 12:01 AM)Sylvain Cote Wrote: [ -> ]When I do not use the card reader, I found that the Spice/Spike cases are perfect for the HP-41C, also, they do not degrade like the original case.
My 41CLs are in the HP-70 case. The zipper goes nearly down to the bottom of the case and you can easily get out the calculator out without scratches.
