01-25-2020, 12:36 AM
Hello
There was an error editing a CAS program outside the program editor.
Steps to reproduce the error.
press the keys [shift]+[1] + Menu: [new]
CAS: ✔
then [ok]
Position the cursor between BEGIN ... END;
if you are operating the simulator copy and paste the next code (Mandelbrot fractal)
In HPConnectivity Kit program editor (2020) still does not allow to put a template for functions of type CAS ={
the EXPORT statement must be removed, then add the #cas directive and the assignment operator :=
In other words, better select all, and delete the template and start writing.
// Mandelbrot fractal
fract1(320,240,10) [enter] correctly draw the fractal [esc] for exit
then
[shift]+[mem] CAS Vars [enter]
fract1 [edit]
the code is shown as
[enter] [edit] [enter] [esc]
fract1(320,240,10) [enter] stays in an infinite cycle
[esc] "append(res1,pixon_p(x,y,126*j+2079)) in fract1(320,240,10) instruction #15 error, try debug(fract1(320,240,10))
Error: Bad Argument Value"
I think the problem is that the COPY() Xcas function is not yet incorporated into the more recent firmware
when writing
it is recoded as
In HPConnectivity Kit shown as
CAS: ✔
then [ok]
PHP Code:
#cas
fract1():=
#end
PHP Code:
EXPORT fract1()
PHP Code:
#cas
fract1(X_,Y_,Nmax):=
local x,y,z,c,j,w,h,res1,res2;
freeze;
w:=2.7/X_;
h:=-1.87/Y_;
res1:=[];
Y_:=Y_-1;
for y from 0 to Y_ do
c:=-2.1+i*(h*y+0.935);
for x from 0 to X_-1 do
z:=0;
for j from 0 to Nmax-1 do
if abs(z:=z^2+c)>2 then break; end;
end;
res1.append(pixon_p(x,y,126*j+2079));
c:=c+w;
end;
end;
return "Done"
#end
then
fract1 [edit]
PHP Code:
(X_,Y_,Nmax)->BEGIN
LOCAL x,y,z,c,j,w,h,res1,res2;
freeze;
w:=(2.7/X_);
h:=(−1.87/Y_);
res1:=copy(NULL);
Y_:=Y_-1;
FOR y FROM 0 TO Y_ DO
c:=−2.1+i*(h*y+0.935);
FOR x FROM 0 TO X_-1 DO
z:=0;
FOR j FROM 0 TO Nmax-1 DO IF (ABS(z:=z^2+c))>2 THEN BREAK ; END ;
END;;
res1::append(pixon_p(x,y,126*j+2079));
c:=c+w;
END;;
END;;
RETURN(Done);
when writing
PHP Code:
res1:=[];
it is recoded as
PHP Code:
res1:=copy(NULL);
PHP Code:
res1:=undef;
