01-18-2020, 03:32 AM
01-18-2020, 03:56 AM
As far as I know, it is... hmm.
01-18-2020, 04:24 AM
I understood that they would leave him with that problem for everyone xD
01-18-2020, 04:34 AM
I reproduced on a single system. All others worked fine...
I made a change, and all were fine. So yeah I do not know.
01-18-2020, 06:35 AM
In my case it remains the same, I have not been able to find the cause, I have had to get used to it: c
01-18-2020, 10:30 AM
(01-18-2020 04:34 AM)Tim Wessman Wrote: [ -> ]I reproduced on a single system. All others worked fine...
Do you mean that after editing the program, it used a monospaced font? What change did you make?
01-18-2020, 10:32 AM
Still the same here.
01-28-2020, 02:20 PM
Is there already a possibility to set the fonts of the program editor (connectivity kit) on monospace? I have probably missed something in discussions on the forum about this.
Prime fonts are present in C: \ Program Files \ HP \ HP Connectivity Kit and HP Prime Virtual Calculator. These fonts are; PrimeSansBold.ttf, PrimeSansFull.ttf and PrimeSansMono.ttf.
I have installed these fonts (character sets) in the windows sub-directory -> fonts.
This did not give the desired result.
What should I do myself, copy these fonts somewhere else?
Or is this still a problem that still needs to be solved by HP?
Windows 10 Home 1909, ConnKit 2.1.14425 (2010 01 16)
