01-12-2020, 03:10 PM
Predicting Freezing Levels
The program FREEZE calculates the freezing elevation heights for two situations:
Dry: Freezing level in clear weather. The Aviation Pac (see source below) uses a drop rate of 2 °C/1000 ft in its calculation.
Wet: Freezing level in clouds on a relatively clear day. Accuracy tends to lessen for cloudy or rainy days. The Aviation Pac (see source below) uses a drop rate of 1.5 °C/1000 ft in its calculation.
In general, the freezing level is calculated as:
FL = ALT + T * drop rate
ALT = altitude of the observer
T = temperature
The program FREEZE allows the user to choose from a set of units: (Fahrenheit vs. Celsius, feet vs. meters).
1. °F, ft
2. °C, ft
3. °F, m
4. °C, m
HP 42S/DM42/Free42 Program FREEZE
Download freeze_level.raw here: https://drive.google.com/open?id=13rIbpy...i1PvQPo-_u
Turn Performance
The program TURN calculates four parameters when it comes to performance of an aircraft:
1. The G-force
2. The stall speed when bank angle is considered
3. The diameter of an airplane's 360° turn
4. The time it takes an airplane to turn 360°
The program sets the calculator to Degrees Mode. The units are in feet for distance and knots for speed.
Memory Registers Used:
Input:
R01 = bank angle, in degrees (prompted)
R02 = true airspeed, TAS, in knots (prompted)
R03 = stall speed, in knots (prompted)
Output:
R04 = G-Force
R05 = turn diameter in nautical miles
R06 = time for a 360° to be completed in minutes
R07 = stall speed when bank angle is considered, in knots
HP 42S/DM42/Free42 Program TURN
Example:
Input:
True Air Speed (cruising speed): 107 knots
Stall speed: 54 knots
Bank: 30°
Output:
G Force: 1.1547
Stall: 58.0268 knots
Diameter: 0.5828 nautical miles
Time: 1.0193 minutes (about 1 minute, 1.1 seconds)
Download turn_performance.raw here: https://drive.google.com/open?id=1a_JFuf...gy_BAZckr0
Source:
"Predicting Freezing Levels" and "Turn Performance" HP 65 Aviation Pac 1. Hewlett Packard, 1974
T = temperature
1. °F, ft
2. °C, ft
3. °F, m
4. °C, m
00 { 204-Byte Prgm }
01▸LBL "FREEZE"
02 "TEMP?"
03 PROMPT
04 CLMENU
05 "°F FT"
06 KEY 1 GTO 01
07 "°C FT"
08 KEY 2 GTO 02
09 "°F M"
10 KEY 3 GTO 03
11 "°C M"
12 KEY 4 GTO 04
13 MENU
14▸LBL 00
15 STOP
16 GTO 00
17▸LBL 01
18 32
19 -
20 1ᴇ3
21 ×
22 ENTER
23 ENTER
24 3.6
25 ÷
26 X<>Y
27 2.7
28 ÷
29 GTO 05
30▸LBL 02
31 1ᴇ3
32 ×
33 ENTER
34 ENTER
35 2
36 ÷
37 X<>Y
38 1.5
39 ÷
40 GTO 05
41▸LBL 03
42 32
43 -
44 1ᴇ3
45 ×
46 ENTER
47 ENTER
48 1.09728
49 ÷
50 X<>Y
51 0.82296
52 ÷
53 GTO 05
54▸LBL 04
55 1ᴇ3
56 ×
57 ENTER
58 ENTER
59 0.6096
60 ÷
61 X<>Y
62 0.4572
63 ÷
64 GTO 05
65▸LBL 05
66 "ALTITUDE?"
67 PROMPT
68 STO+ ST Z
69 STO+ ST Y
70 R↓
71 CLMENU
72 EXITALL
73 "Y: DRY X:WET"
74 AVIEW
75 STOP
76 RTN
77 .END.
Example:
Temperature: 40 °F
Altitude: 3970 ft (choose °F, ft)
Results:
Dry: 6192.2222 ft
Wet: 6932.9630 ft
Turn Performance
1. The G-force
Input:
Output:
R04 = G-Force
00 { 157-Byte Prgm }
01▸LBL "TURN"
02 DEG
03 "SPEED IN KNOTS"
04 AVIEW
05 PSE
06 PSE
07 "TRUE AIR SPEED?"
08 PROMPT
09 STO 02
10 "NORM STALL?"
11 PROMPT
12 STO 03
13 "BANK? °"
14 PROMPT
15 STO 01
16 COS
17 1/X
18 STO 04
19 "G FORCE:"
20 ARCL ST X
21 AVIEW
22 STOP
23 SQRT
24 RCL× 03
25 STO 07
26 "STALL: "
27 ARCL ST X
28 AVIEW
29 STOP
30 RCL 01
31 TAN
32 1/X
33 RCL× 02
34 ENTER
35 ENTER
36 RCL× 02
37 34028
38 ÷
39 STO 05
40 "DIA: "
41 ARCL ST X
42 ├" N.M."
43 AVIEW
44 STOP
45 X<>Y
46 55ᴇ-4
47 ×
48 STO 06
49 CLA
50 ARCL ST X
51 ├" MIN"
52 AVIEW
53 .END.
Input:
Bank: 30°
Output:
G Force: 1.1547
Source:
