Full Version: (11C) Probability of No Repetitions
This program was adapted from HP-55 Statistic Book (Page 12)
Reference:
E. Parzen, Modern Probability Theory and its Applications,
John Wiley and Sons, 1960 (CH. 2 Page 46)
As stated in the book:
Probability of No Repetitions in a Sample
Suppose a sample of size n is drawn with replacement from population
containing m different objects. Let P be the probability that there are no
repetitions in the sample, then
P = [1- (1/m)][1- (2/m)]....[1- (n-1/m)]
Given integer m, n such that m ≥ n ≥ 1 this program finds the probability P.
Remark:
The execution time of the program depends on n; the larger n is, the longer it takes.
Example: HP-55 Statistic Book page 13
In a room containing n persons, what is the probability that no two or more
persons have the same birthday for n = 4, 23, 48?
Note: m = 365 // 365 is the days amount of birthday
[USER] [FIX] 2
365 [A] display 365.00 // Enter m
4 [B] display brieftly 0.98 then 2.00 // Enter n
23 [B] display briefly 0.49 the 51.00
48 [B] display briefly 0.04 then 96.00
Answer:
In a room for the probability that at lease two of them will
4 people in a room P = 0.98 or only 2%
23 people in a room P = 0.49 or 51%
48 people in a room P = 0.04 or 96%
Program:
LBL A  // m
STO 1
RTN
LBL B  // n
STO 2
1
STO 0
LBL 0
RCL 1
RCL 2
1
STO 2
0
X=Y
GTO 1
Rv
X<>Y
1
X<>Y
STOx0
GTO 0
LBL 1
RCL 0
PSE
1
RCL 0
RND
EEX
2
x
RTN
Gamo 1/2020
(01-10-2020 12:42 PM)Gamo Wrote: [ -> ]Probability of No Repetitions in a Sample
P = [1- (1/m)][1- (2/m)]....[1- (n-1)/m]
This is similar to thread (42S) Probability of Same Birthday Day
We can do approximation the same way: products of terms = exp of sum of ln(term)
Sum is approximated by integral with correction (bolded expression below)
If we let u = 1-x/m, we have x = m-m*u
XCas> f := ln(1-x/m)
XCas> expand(subst(int(f) - f/2 + diff(f)/12, x = m-m*u))   → m*u - 1/(12*m*u) - ln(u)/2 - m*u*ln(u)
XCas> g(m,u) := -1/(12*m*u) - ln(u)*(0.5 + m*u) + m*u       // ≈ sum formula
XCas> p(m,n) := exp(g(m, 1.-n/m) - g(m, 1.-1/m))                 // ≈ product(1-x/m, x=1 .. n-1)
XCas> p(365, 4)       → 0.9836440875
XCas> p(365,23)      → 0.4927027657
XCas> p(365,48)      → 0.03940202712
(01-10-2020 12:42 PM)Gamo Wrote: [ -> ]P = [1- (1/m)][1- (2/m)]....[1- (n-1)/m]
Perhaps it is more useful by adding a (1-0/m) term, we have P = perm(m,n) / mn
Using the same idea to approximate ln(perm(m,n)):
XCas> f := ln(m-x)
XCas> expand(subst(int(f) - f/2 + diff(f)/12, x = m-u))     → -1/(12*u) - ln(u)/2 - u*ln(u) + u
XCaS> g(u) := -1/(12*u) - ln(u)/2 - u*ln(u) + u
XCas> ln_perm(m,n) := g(m-n) - g(m)                                 // integral limit x = 0 to n, u=m-x
ln_perm() can be simplified and more accurate by putting tiny terms up front, and use logp1()
\(\large \ln(perm(m,n)) ≈ {-n\over 12m(m-n)} - [n + (m-n+½)\ln(1 - n/m)]+ n \ln(m)
For ln(P), above last term cancelled out.
XCas> ln_P(m,n) := -n/(12*m*(m-n)) - (n + (m-n+0.5)*ln(1-n/m))
XCas> ln_perm(m,n) := ln_P(m,n) + n*ln(m)
XCas> e^ln_P(365, 4)       → 0.9836440875
XCas> e^ln_P(365,23)      → 0.4927027657
XCas> e^ln_P(365,48)      → 0.03940202712
Trivia: ln_perm(m,n) = ln_perm(m,a) + ln_perm(m-a, n-a), same as real permutation function.
if m ≈ n, ln_perm(m,n) is not very accurate.
With above trivia, splitting ln_perm(m,n) does not help.
However, we can replace the 2nd term with real ln(perm(m-a,n-a))
Example: ln(perm(69,68)) = ln(69!) ≈ 226.1905483
XCas> ln_perm(69,68)                   → 226.1882765 // slightly worse than log of Stirling's formula.
XCas> ln_perm(68,67) + ln(2)        → 226.1902224 // perm(69-67, 68-67) = perm(2,1) = 2
XCas> ln_perm(68,66) + ln(6)        → 226.1904485 // perm(69-66, 68-66) = perm(3,2) = 6
Edit: above ln_P formula is numerically very bad, use this instead
