Full Version: eigenvects function returning wrong answers for complex eigenvectors
I was working on a problem and was getting funny results. I thought there was an issue with my matrices because I didn't expect the calculator to be giving wrong results.
Before, I present the issue, I want to point out that the function works fine for matrices with real eigenvalues/eigenvectors. In the last step, I'm using the matrix diagonalization formula.
[Image: real.png]
This is the matrix I'm working on. It has two complex conjugate eigenvalues (and therefore eigenvectors). Because the eigenvector matrix returned is wrong, I wasn't able to get the original matrix using the matrix diagonalization formula, as was the case in the previous example.
[Image: complex.png]
If I manually enter the correct eigenvectors, I get the original matrix. This proves that the eigenvects function is returning wrong results when the eigenvectors are complex. The correct eigenvectors are shown in the "m" matrix.
[Image: complex2.png]
The reason is that eigVl and eigenvects do not necessarily sort the eigenvectors the same way. You should use jordan to compute both simultaneously:
a:=[[0,0.1],[-1,-0.2]];
p,d:=jordan(a);
p*d*p^-1;
In addition, this is more efficient (for large matrices).
(01-02-2020 09:05 AM)parisse Wrote: [ -> ]The reason is that eigVl and eigenvects do not necessarily sort the eigenvectors the same way. You should use jordan to compute both simultaneously:
p,d:=jordan(a);
p*d*p^-1;
I'm actually not interested in using the diagonalization formula. What I'm interested in is the result from the eigenvects function. Why doesn't the function return a simple answer?
[[-0.1-0.3*i, -0.1+0.3*i],[1,1]] - this is the simple answer I expect. Instead, what I got is something that doesn't even tell me that the eigenvectors are complex conjugates. I've tried it on Wolfram alpha and lots of other websites and all of them return [[-0.1-0.3*i, -0.1+0.3*i],[1,1]].
In this case, I agree. The matrix is 2x2 real, and has complex conjugate eigenvalues and thus complex conjugate eigenvectors. The 48GX series gets it right.
Cheers, Werner
The algorithm I'm using for diagonalization is a generic algorithm that does not check for real matrix/complex conjugate answers. I'd like to point that *the answer is perfectly correct, not wrong* : you can multiply an eigenvector by any non-zero constant and you will still get an eigenvector, the title of this thread is therefore misleading.
Remarks:
1/ for approx matrices, the expected normalization of eigenvectors is probably a vector of norm 1. For exact matrices, I don't think there is a convention.
2/ eigenvects(exact(a)) or jordan(exact(a)) returns simple answers, and you can of course replace in this answer an eigenvector by the conjugate eigenvector of the conjugate eigenvalue.
(01-03-2020 03:25 PM)parisse Wrote: [ -> ]1/ for approx matrices, the expected normalization of eigenvectors is probably a vector of norm 1. For exact matrices, I don't think there is a convention.
These are better. I never knew that it was convention to normalize the last row of a the eigenvector matrix to 1 if the results were approximate. Maybe, I'll write a small routine to take care of that.
