Is there a way to plot the part of the graph of 1/(5root(x-1)) where x<1 in the advanced graphing environment? It plots in the regular graphing environment.
(12-31-2019 07:12 PM)lrdheat Wrote: [ -> ]Is there a way to plot the part of the graph of 1/(5root(x-1)) where x<1 in the advanced graphing environment? It plots in the regular graphing environment.
Maybe you need to define it piecewise?
(busy testing other things - gotta finish this year)
attachment=9728]
Is this what you were trying to plot? It seems to work on the current Windows version (namely 2.1.14592 (2021 06 09)). That said, the Advanced Graphing app should be set up for more automated (regression) testing as it can be very sensitive to compiler settings etc. (Compilers can play a bit fast and loose with how floating-point arithmetic instructions get turned into object code.)
