All intra-line whitespace below the ruler line consists of ASCII TAB characters. Will the tab stops line up?
12345678901234567890123456789012345678901234567890
a a a a a
ab ab ab ab ab
abc abc abc abc abc
abcd abcd abcd
abcde abcde abcde
abcdef abcdef abcdef
abcdefg abcdefg abcdefg
Nope.
Never use tabs for anything on the web. Use explicit spaces instead, like this:
a a a a a
ab ab ab ab ab
abc abc abc abc abc
abcd abcd abcd
abcde abcde abcde
This actually is a Good Thing, since tab width is variable and therefore unpredictable in plain-text files, whereas spaces are predictable in code blocks in this forum.
(12-30-2019 01:14 PM)Joe Horn Wrote: [ -> ]Never use tabs for anything on the web. Use explicit spaces instead, like this:
a a a a a
ab ab ab ab ab
abc abc abc abc abc
abcd abcd abcd
abcde abcde abcde
Hi Joe, I'm aware of that. The issue of tab stops not lining up came up in a recent thread, so I just created this thread to demonstrate the current behaviour.
In theory, it is fixable in the MyBB PHP code (and it would be great if it that also had an option to set the tab width, using something like [code tabwidth=8], for example), although I'm not expecting it to get fixed. The PHP code would just need to work out how many entities to emit for each TAB character, instead of always emitting exactly four entities.
