Could you help me?
I have a HP41CX
When I'm using some HP-IL printer, like HP2225C, I'd like to print the TIME and DATE in first line.
Thanks for help me
(12-29-2019 07:27 PM)Dinamarco Wrote: [ -> ]Could you help me?
I have a HP41CX
Thanks for help me
This is probably clunky, but seems to work:
CLA
TIME
ATIME
DATE
ADATE
PRA
Nice....
I tried but...
CLA
TIME
ATIME
|-" " (how do I type it in HP41cx ?)
DATE
ADATE
PRA
Could you answer me?
It is the "APPEND" Symbol
ALPHA - SHIFT - K
Followed by a Space.
ok. Thanks a lot!
Another simple question: Is possible to print an simple text after a question, for example:
NAME?
PROMPT
DINAMARCO
(12-31-2019 02:41 PM)Dinamarco Wrote: [ -> ]...
I tried but...
Sorry I did not see your question sooner, I should have realized that the APPEND function might not be obvious. Thanks to twoweims for answering.
I also realized my code could use some more work. The ATIME and ADATE functions observe or obey the current display mode to some exent, so some FIX commands would be needed to insure a pleasing output. Something like the below gives good results:
CLA
FIX 02
TIME
ATIME
DATE
FIX 04
ADATE
PRA
Above provides hours and minutes for the time, for example, if I execute it at this very moment, I get:
12:40 PM 12/31/19
If hours minutes and seconds are preferred, just put a FIX 04 at the beginning and get:
12:40:15 PM 12/31/19
If DMY is preferred:
12:40 PM 31.12.19
If 24 hour time is prefrerred:
12:40 31.12.19
If you want the whole year, replace the FIX 04 with a FIX 06:
12:40 PM 12/31/2019
Thanks DAVE...
I wrote it in my small program.
Best Regards...
(12-31-2019 03:08 PM)Dinamarco Wrote: [ -> ]Another simple question: Is possible to print an simple text after a question, for example:
NAME?
PROMPT
DINAMARCO
On the LCD no (well, yes but not really), on the printer yes.
LBL "TEST" // test program
AON // ALPHA ON
"NAME ? " // question
ACA // add ALPHA content (question) to printer buffer, no CR+LF added
PROMPT // show question on the LCD, wait for user to enter his name and then press R/S to restart the program
AOFF // ALPHA OFF
PRA // add alpha content (user name) to printer buffer, add CR+LF and print buffer
END // end of program
Printer output:
Solved!!!
Thanks a lot for everyone who help me!
Happy new year!!!
Happy new year every one!
Late and probably a bit outside the scope but here's a few line of code I use to display the date in french.
01◆LBL "JOUR"
02 DATE
03◆LBL D
04 DOW
05 XEQ IND X
06 "|- "
07 RCL d
08 FIX 2
09 SF 28
10 ARCL L
11 STO d
12 AVIEW
13 CLX
14 LASTX
15 RTN
16◆LBL 00
17 "DIMANCH."
18 RTN
19◆LBL 01
20 "LUNDI"
21 RTN
22◆LBL 02
23 "MARDI"
24 RTN
25◆LBL 03
26 "MERCRED."
27 RTN
28◆LBL 04
29 "JEUDI"
30 RTN
31◆LBL 05
32 "VENDRED."
33 RTN
34◆LBL 06
35 "SAMEDI"
36 END
Once the pointer in the program, 03 LBL D is there to display any given date in X.
Line 06 is Append Space.
Lines 07 & 11 are synthetic instructions to keep the previous status (flags) of the 41, they can be omitted.
Also this nice to see that there's still HP2225C printers out there. Mine is out of order cause the cartridge wasn't removed by the previous owner.
(01-01-2020 03:25 PM)dayd Wrote: [ -> ]Late and probably a bit outside the scope but here's a few line of code I use to display the date in french.
Alternative implementation using X<>F instead of XEQ IND X.
DOW converted into flags with X<>F
000 : DIM / SUN
001 : LUN / MON
010 : MAR / TUE
011 : MER / WED
100 : JEU / THU
101 : VEN / FRI
110 : SAM / SAT
111 : not used
Program listing: (based on yours)
LBL "JOUR"
DATE
LBL D
DOW
X<>F
FC? 02
GTO 00
"JEU"
FS? 01
"SAM"
FS? 00
"VEN"
GTO 01
LBL 00
FC? 01
GTO 00
"MAR"
FS? 00
"MER"
GTO 01
LBL 00
"DIM"
FS? 00
"LUN"
LBL 01
X<>F
RCL d
FIX 2
SF 28
ARCL L
STO d
AVIEW
CLX
LASTX
RTN
Nice...
I'm able to translate to Portuguese
Regards.
Nice 2020!
I'm able to send you another "head" from HP2225.
If you want it, let me know.
you gonna pay only the Shipping.
Best regards.
Thanks again for your help
Indeed, I'm interested...
[PM sent]
André
(01-01-2020 08:56 PM)dayd Wrote: [ -> ]Indeed, I'm interested...
[PM sent]
André
Do you speak Portuguese or English?
send me a private message with your address.
Let you know the shipping cost.
I'm not sure the part will work, but,,, let's try.
Nelson Dinamarco
Quote:Do you speak Portuguese or English?
Both (in a limited way), and french of course.
Very nice! Would love to see it working.
Thanks a lot
[re-PM]
Quote:Alternative implementation using X<>F instead of XEQ IND X.
Always cool to see others way of writing code
