07-12-2014, 09:16 PM
Pages: 1 2
07-13-2014, 11:39 AM
Just in case, I hear entropy is not what it used to be.
07-13-2014, 11:40 AM
(07-13-2014 11:39 AM)Gene Wrote: [ -> ]Just in case, I hear entropy is not what it used to be.
Became a bit chaotic recently.
08-15-2014, 08:52 PM
08-16-2014, 07:09 AM
(08-15-2014 08:52 PM)ovael Wrote: [ -> ]Edit. So I couldn't use quote right and I came here to test it.Found that post. The Problem is the [Quote] keyword within a quote. It only works outside of it apparently but don't count on it. Generally don't use meta tags without their closing tags.
08-16-2014, 04:03 PM
Correct. I didn't anticipate that somebody would quote that. But there were more tags missing ...
d:-)
d:-)
08-17-2014, 07:52 AM
(08-16-2014 04:03 PM)walter b Wrote: [ -> ]Correct. I didn't anticipate that somebody would quote that. But there were more tags missing ...
d:-)
Well I couldn't use multiquote since I thought there is something wrong with the <new reply> button since you mentioned <new reply> causing problems so the post came out messy... And I have not bothered to look into tags before since I generally don't post to forums. But I learned something new! All though pretty trivial... :-)
Edit: Oh, and I learned that there is a threaded mode too!
Pages: 1 2
