Full Version: Base Conversions (to any base 2-36)
Blog Link: http://edspi31415.blogspot.com/2019/12/h...sions.html
Introduction
The program BASEDEC converts a number in a base representation to decimal (base 10). BASEDEC accepts any positive number, including non-integers up to base 36. Each of the letters of alphabet represents a value:
A = 10
B = 11
C = 12
D = 13
E = 14
F = 15
Z = 35
BASEDEC takes two arguments: number to be converted, entered as a string; and the base representation of the number.
Examples:
BASEDEC("531",8) converts 531_8 to decimal. Result: 345
BASEDEC("63.95A", 11) converts 63.95A_11 to decimal. Result: 69.86701728
BASEDEC("4H", 18) converts 4H_18 to decimal. Result: 89 (H = 17)
HP Prime Program BASEDEC
EXPORT BASEDEC(s,b)
// string, original base
// number can have fractional
// part in decimal form
// convert to base 10
// A=10,B=11,C=12...Z=35
// 2019-12-09 EWS
LOCAL l,pt,sl,sr,ls,lr,d;
LOCAL k,ac,al,dg,sd;
d:=0; // decimal
l:=DIM(s);
// split the string
pt:=INSTRING(s,".");
CASE
IF pt==0 THEN
sl:=s;
sr:="";
IF pt==1 THEN
sl:="";
sr:=RIGHT(s,l-1);
DEFAULT
sl:=LEFT(s,pt-1);
sr:=RIGHT(s,l-pt);
// conversion to decimal
// integer part
ls:=DIM(sl);
IF ls>0 THEN
FOR k FROM 1 TO ls DO
sd:=MID(sl,k,1);
ac:=ASC(sd);
al:=ac(1);
dg:=when(al>64,al-55,EXPR(sd));
d:=d+dg*b^(ls-k);
// fractional part
lr:=DIM(sr);
IF lr>0 THEN
FOR k FROM 1 TO lr DO
sd:=MID(sr,k,1);
ac:=ASC(sd);
al:=ac(1);
d:=d+dg/(b^k);
// return decimal
RETURN d;
Introduction Part II
The program DECBASE converts a number in decimal form to any base you want. DECBASE works will all positive real numbers. There are three arguments to DECBASE:
* The number in decimal form
* The desired base
* Accuracy: how many decimal points do you want. Conversions from decimal to other bases are approximations. If the number is a integer (frac(number) = 0), then this argument is ignored (put 0).
The result is returned as a string.
Examples:
DECBASE(69, 6, 0) converts 69 to base 6. Result: "153"
DECBASE(5.875, 8, 4) converts 5.875 to base 8 to four decimals. Result: "5.7000" (exact: 5.7_8)
DECBASE(635.05, 12, 12) converts 635.05 to base 12 to twelve decimals. Result: "44B.072497249724" (exact: 44B.07249..._12 (7249 repeats))
HP Prime Program DECBASE
EXPORT DECBASE(d,b,acc)
// decimal, base, accuracy
// convert from decimal to base
// 2019-12-09 EWS
LOCAL n,f,nl,nd;
LOCAL nf,k,dg,s,fd;
n:=IP(d); // integer
f:=FP(d); // fractional
s:="";
// integer
IF n>0 THEN
nl:=IP(LOG(n)/LOG(b));
nd:=n;
FOR k FROM nl DOWNTO 0  DO
dg:=IP(nd/(b^k));
IF dg<10 THEN
s:=s+STRING(dg);
ELSE
s:=s+CHAR(dg+55);
nd:=nd-dg*b^k;
// numbers < 1
IF n==0 THEN
s:="0";
// fractional part
IF f>0 THEN
s:=s+".";
fd:=f;
FOR k FROM 1 TO acc DO
dg:=IP(fd*b^k);
IF dg<10 THEN
s:=s+STRING(dg);
ELSE
s:=s+CHAR(dg+55);
fd:=fd-dg/(b^k);
RETURN s;
Nice programs!
if I run the program using Shift Program and use the fill form all is well, but if I run from home screen as
BASEDEC("531",8) I get
0+when(al>64,al-55,EXPR(sd))*324+when(al>64,al-55,EXPR(sd))*18+when(al>64,al-55,EXPR(sd))*1
This is on android 2.1.14346 (2019 11 21)
Wonder why the when() statements not being evaluated?
That's a strange result. Possibly a bug?
Thank you for the compliment!
Happy 2PI! (in base 26) Big Grin
