12-27-2019, 03:09 PM
Basically, whenever I install a program in the virtual calculator I get no errors and they work flawless. But, when using the calculator I need to insert this command to make them work:
#pragma mode( separator(., integer(h32) )
But even some problems aren't solved with this, I found the command browsing the internet, and i guess it has to do with my configuration.
Is there anyway to "mirror" the virtual calculator configuration and solve compatibility problems?
(Software is updated)
