12-26-2019, 12:21 AM
I was told that an Euler's method program would be easy to make... On this forum? Somewhere... anyway that doesn't matter. I think it should be an easy program.
I'm getting an Invalid Input error and I think it has something to do with passing a function. I have this 'slopefield' app that someone wrote and I tried to pass the function the same way he did it... But it doesn't work for me in this instance.
By the way... I'm just learning about differentials AND programming. So maybe I'm doing something all wrong.
Obviously there would be a return or a print of s after the loop finishes. I didn't get that far in programming yet.
While previewing the post, I just had a thought... 'maybe I'm doing the matrix wrong.'
sample input
EXPORT eulerm(funct,X0,Y0,ch,times)
LOCAL a, s,check,x,y,myfunct;
myfunct:=EXPR(funct);
RETURN(myfunct(x,y));
MAKEMAT(0,times,2)▶s;
check=0;
FOR a FROM 0 TO times DO
IF check==0 THEN
s(a,0):=X0;
s(a,1):=Y0;
check:=1;
ELSE
s(a,0):=s(a-1,0)+ch;
x:=s(a,0);
y:=s(a-1,1);
s(a,1):=y+(myfunct)*ch;
sample input
eulerm("(3-y)*(y+1)",0,4,1,5)
