12-20-2019, 09:40 PM
I attempted to write an application which would optimize the function, and then display it on the screen using built-in Function app.
It worked functionally, but I ran into UI problems I could not work around.
Here is a simple application illustrating the problem:
The application exports a function converting gas mileage from mpg to l/100km (somehow this problem came to mind to be used as an example...). No fanciness, just bare-bones. Even slot unchecking is done sequentially, not in a loop.
After the program is finished, it displays the dialog box. This dialog box can be used for displaying additional info, like in the example. The problem is with the behavior of the screen after the dialog box is displayed.
This dialog box is *not* a modal one, like one could expect. If you start making sweeping gestures on the screen when it's displayed, the screen moves, and its contents get badly distorted. When the dialog box is closed (either by pressing soft Okay of hard Enter), the screen remains damaged, and to fix it you have to move it such that the distorted area is shifted out of the display area.
Technically a small thing, but very annoying.
Does anybody know of a better way to deal with a problem of invoking Function app from the code?
Darius
#pragma mode( separator(.,;) integer(h64) )
EXPORT GAS()
Function.F0:='3.79/(1.605*X)*100';
Function.Xmin:=0;
Function.Xmax:=50;
Function.Ymin:=0;
Function.Ymax:=25;
Function.CHECK(0);
Function.UNCHECK(1);
Function.UNCHECK(2);
Function.UNCHECK(3);
Function.UNCHECK(4);
Function.UNCHECK(5);
Function.UNCHECK(6);
Function.UNCHECK(7);
Function.UNCHECK(8);
Function.UNCHECK(9);
STARTAPP("Function");
STARTVIEW(1,1);
RETURN("X - mpg, Y - l/100km, Press OK or Enter to continue...");
Darius
