12-12-2019, 11:33 PM
How do I get this function to evaluate...
All I get is the name of the function returned
(The Python string syntax may need correcting too
CAS file:
#cas
HAMMINGCAS():=
def hammingdistance(s1, s2) -> int:
"""Return the Hamming distance between equal-length sequences."""
if len(s1) != len(s2):
raise ValueError("Undefined for sequences of unequal length.")
count = 0
for ii in s1
el1 = s1(ii)
el2 = s2(ii)
if el1 != el2:
count = count+1
return count
"""return sum(el1 != el2 for el1, el2 in zip(s1, s2)) """
#end
PPL file:
EXPORT TRY()
LOCAL ST1:="AB";
LOCAL ST2:="AB";
RETURN CAS("eval(hammingdist(ST1,ST2))");
EXPORT HAMMING()
//def hamming_distance(s1, s2) -> int:
// """Return the Hamming distance between equal-length sequences."""
// if len(s1) != len(s2):
// raise ValueError("Undefined for sequences of unequal length.")
// return sum(el1 != el2 for el1, el2 in zip(s1, s2))
