12-11-2019, 09:27 AM
This equation works on the iPhone HP 17Bii simulator, but gives a "SOLUTION NOT FOUND" error on the actual HP 17Bii calculator. Where it goes wrong is in the DATE(actual_date:#days) function. If I put in a numerical value for #days, the equation works on the calculator, but when I use a calculated value, it fails. Should I do something different, or is this not possible in the 17Bii?
The equation should give the date of the first Advent Sunday:
advdate = date(xmas:(7*fp(ddays(1.011900:xmas:1)/7)+22)*-1)
If I change the second argument of date() in a constant, then it works. I have also tested putting the second argument in a variable first, and using that variable in the date() function, with the same result (SOLUTION NOT FOUND). Again, this works in the iPhone simulator, but fails on the calculator.
Thanks!
Edit: found it; I should put RND(x:0) around it, to avoid rounding errors!
Thanks!
