05-25-2014, 09:40 PM
Some 34s quantile functions for the statistical distributions do not seem to work as fast and reliably as they could. I recently suggested an update for Student's t quantile, based on a new estimate and the Halley method for fast convergence.
I now would like to propose a similar solution for the Chi² quantile. Here things are a bit more complex: a regular Halley iteration can be set up easily, as shown in another earlier thread, but there are issues with large degrees of freedom. Although the first Chi² estimate is only approx. 11% low in the worst case, this can mean that the CDF of this can be off by several orders of magnitude. This leads to very slow convergence in the first 2...10 iterations which essentially apply the same correction until the estimate is sufficiently accurate and rapid convergence starts.
So I chose a different approach: instead of cdf(x) – p, better solve ln(cdf(x)/p) = 0. This requires a bit of calculus, but it is not too hard to do.
The Student case was already discussed earlier, so the code below is just a slight update. Please note that the incomplete Beta function recently was updated and now requires a new order of its three arguments in X, Y and Z. The code below assumes the previous order.
Compared to the current version included in the 34s, the Normal quantile was streamlined and shortened. It also takes advantage of the new Normal estimate.
The result below is part of a set of programs for the Normal, Student and Chi² quantile. They all rely on a short routine that provides an estimate for the Normal quantile. Compared to the routine previously used in the 34s, only some constants were changed to provide better accuracy. More important, "GNQ" now accepts any probability between 0 and 1 (exclusively) and it returns a correctly signed result. As an additional benefit, min(p, 1–p) is returned in Y which can be handy here and there.
Finally, the following set of programs is what I got until now. This code is to be run in double precision mode, four stack levels are sufficient. As usual, the number of degrees of freedom is assumed in register J. Otherwise the programs only use R00 and R01 and flags 00 and 01. I could not find any severe errors, but please do your own thorough tests and do not consider this perfect. As usual, any error reports and suggestions are welcome.
Edit: there was an update in the incomplete Beta function. If your 34s displays this function as "Iβ" you are running the older version and the original code above works fine. If the function is named Ix instead, this is the newer version with a different order of the three arguments. In this case use the following code between LBL 02 and 03 in "TQF":
And finally: Pauli, what do you think ?-)
Dieter
*LBL'NQF' // Normal quantile function
XEQ'GNQ'
CF 00
x<0?
SF 00 // save sign in flag 00
x[<->] Y
STO 00 // store min(p, 1-p)
# 002
STO 01 // not more than 2 iterations are required
RCL Z
ABS
FILL
INC X
RSD 03
x[!=]1?
GTO 000
DEC 01 // estimate < 0.005 requires just one iteration
DROP
SDL 016
x>1?
GTO 000
DROP // estimate < 5E-17 is already exact
GTO 004
*LBL 000
DROP
*LBL 001
FILL
x<1? // any threshold between 0.254 and 1.28 should be ok
GTO 002
[PHI][sub-u](x)
RCL- 00
GTO 003 // large x: evaluate upper cdf(x) - p
*LBL 002
x[^2] // small x: evaluate (0.5-p) minus integral from 0 to x
# 1/2 // by means of the incomplete Gamma function
[times]
# 1/2
I[GAMMA][sub-p]
RCL[times] L
# 1/2
RCL- 00
*LBL 003
x[<->] Y
[phi](x)
ENTER[^] // use extrapolation scheme as shown in Abramowitz & Stegun p. 954
x[^3]
RCL T
x[^2]
STO+ X
INC X
[times]
# 006
# 1/2
RCL[times] T
RCL[times] Z
RCL[times] Z
DSE 01
GTO 001
*LBL 004
FS?C 00 // adjust sign
+/- // and exit
END
*LBL'TQF' // Student's t quantile function
ENTER[^]
INC X
MIN
CF 00
x[!=]? L
# 006
STO 01 // do at most 6 iterations (usually 3 or 4)
# 012
RCL J
y[^x]
RCL 00
x>? Y // threshold for tail estimate is p = 12^(-dof)
GTO 000
RCL J // tail estimate for p close to 0 (or 1)
STO+ X
[times]
# [pi]
RCL L
# 1/2
x[^2]
DEC X
[sqrt]
[times]
RCL J
[^x][sqrt]y
RCL J
[sqrt]
x[<->] Y
GTO 001 // start iteration
*LBL 000
XEQ'GNQ' // estimate for all other p, *not* close to 0 or 1
x[^2] // t is a tranformation of the Normal z-quantile
# eE
RCL[times] J
1/x
INC X
[times]
RCL/ J
e[^x]-1
RCL[times] J
[sqrt]
*LBL 001
FILL
# 1/2 // use different methods for evaluating cdf(t) - p
x>? Y // for t close or not close to the center
GTO 002
DROP
t[sub-u](x)
RCL- 00
GTO 003
*LBL 002
DROP
x[^2] // for t close to the center
ENTER[^] // evaluate cdf(t) - p by means of the incomplete Beta function
RCL+ J
# 1/2
RCL[times] J
RCL L
I[beta] // IMPORTANT: newer 34s firmware requires different order of arguments! See below.
RCL[times] L
# 1/2
RCL- 00
*LBL 003
RCL T // use Halley method for fast convergence
t[sub-p](x)
ENTER[^]
RCL[times] T
RCL J
INC X
[times]
RCL T
x[^2]
RCL+ J
STO+ X
DEC X
CNVG? 00 // if the last two approximations agree in 14 digits
SKIP 003 // the latest result can be considered converged
DSE 01
GTO 001
ERR 20 // quit with error if no convergence within 6 iterations
FS?C 00
+/- // else set sign and exit
END
*LBL'CQF' // Chi^2 quantile function
x=0?
RTN // catch case p = 0
STO 00
# 006
STO 01 // do at most 6 iterations (usually 3...4)
# 019
SDR 001 // threshold for lower tail estimate is 1/pi * 1.9^-n
RCL J
x=1?
DEC X // handle threshold for 1 dof separately (1/pi is fine)
y[^x]
# [pi]
RCL 00
x<? Y
GTO 000 // jump to lower tail estimate
XEQ'GNQ' // else get correctly signed Normal quantile
# 222 // and do a Wilson-Hilferty transformation
SDR 003
RCL/ J
STO Z
[sqrt]
[times]
INC X
RCL- Y
x[^3]
RCL[times] J // Wilson-Hilferty estimate
# eE // is adjusted for p close to 1
RCL[times] J // i.e. for Chi^2 > e*dof + 8
# 008
x[<->] Y
x<? Y // Chi^2 not large?
GTO 001 // then start iteration
# 1/2 // otherwise adjust estimate
[times]
LN
# 1/2
RCL[times] J
DEC X
[times]
RCL 00
LN1+x
# 1/2
RCL[times] J
LN[GAMMA]
STO+ X
GTO 001
*LBL 000 // lower tail estimate
RCL[times] J
# 1/2
[times]
LN
# 1/2
RCL[times] J
LN[GAMMA]
STO+ X
RCL/ J
e[^x]
STO+ X
*LBL 001 // iteration starts here
FILL // uses Halley method for f(x) = ln(cdf(chi^2) / p)
x[>=]? J // with different methods for low and high Chi^2
GTO 002
[chi][^2] // low Chi^2
ENTER[^]
RCL/ 00
LN
GTO 003 // provide lower cdf in Y and ln(cdf/p) in X
*LBL 002
# 001
ENTER[^]
RCL- 00
RCL Z
[chi][^2][sub-u]
STO- Z // Z := 1-Z, i.e. upper cdf => lower cdf
RCL/ 00 // provide lower cdf in Y and ln1+x((1-p) - upper_cdf) / p) in X
LN1+x // the latter is mathematically equivalent to ln(lower_cdf/p)
*LBL 003
x[<->] Y // start Halley approximation
RCL Z
[chi][^2][sub-p]
x[<->] Y
STO Z
RCL J
DEC X
DEC X
RCL- T
RCL/ T
[<->] ZXYT // all this can be done with four stack levels ;-)
STO+ X
# 004
RCL[times] Y
INC X
DSE 01
GTO 001
END // else exit
**LBL'GNQ' // Provides a guess for the Normal quantile
ENTER[^] // input: 0 < p < 1
+/- // output: X = signed quantile, Y = min(p, 1-p)
INC X // max. absolute and relative error < 0.006
MIN
CF 01
x[!=]? L
SF 01 // save sign in flag 01
# 002
SDR 001 // threshold is 0.2 (was 0.23 before)
x[<->] Y
x[>=]? Y // use different estimates for p < or > 0.2
GTO 000
FILL // tail estimate for p < 0.2 or > 0.8
LN
STO+ X
ENTER[^]
DEC X
# [pi]
[times]
STO+ X
[sqrt]
RCL[times] T
LN
STO+ X
[sqrt]
x[<->] Y
# 132
STO+ X
SDR 003 // 0.264 (was 0.254 in earlier versions)
x[<->] Y
GTO 001
*LBL 000
ENTER[^] // central estimate for 0.2 < p < 0.8
# 1/2
# [pi]
STO+ X
[sqrt]
[times]
ENTER[^]
x[^3]
# 005 // was 6 in earlier versions
*LBL 001
FS?C 01 // adjust sign
+/- // negative for p<0.5, positive for p>0.5
END
*LBL 002
RCL[times] J // X was 1/2, so this is n/2
x[<->] Y
x[^2]
ENTER[^]
RCL+ J
/ // x = t²/(t²+n)
# 1/2
x[<->] Y // stack now is x 1/2 n/2 t
I[sub-x]
# 1/2
[times]
# 1/2
RCL- 00
*LBL 003
Dieter
