11-27-2019, 09:54 PM
These four programs compute the EXP (exponential), LOG (logarithmic), MNL (multinomial) and IML (inverse multinomial) transforms of number sequences. Definitions and examples can be found at A274804, A274805, A274760 and A274844.
These programs require the GoferLists and ListExt libraries. They are listed here as a directory (DIR) object for convenience and because IMLXF calls LOGXF. The two pairs of transforms (EXP and LOG), (MNL and IML) are inverses, meaning that if a sequence is transformed by first one transform then the other, the original sequence will return.
The transforms listed here may return (non-integer) rational numbers as terms, and all four programs will accept lists with rational number terms. That is the reason for the EVALs in each program.
DIR
EXPXF
\<< DUP SIZE R\->I \-> b n
\<< b 1. 1. SUB { 1 } 2 n
FOR k 0 + :: + DOSUBS DUP2 * b 1 k SUB LPOPR
UNROT REV * LSUM + EVAL ROT SWAP + SWAP 1 SWAP +
NEXT DROP
LOGXF
\<< b 1. 1. SUB { } 2 n
FOR k 1 SWAP + 1 + :: + DOSUBS DUP2 * b 1 k SUB LPOPR
UNROT REV * k 1 - LSEQ * LSUM k / - EVAL ROT SWAP + SWAP
NEXT DROP
MNLXF
\<< n 1 - LSEQ 1 :: * Scanl b 1. 1. SUB 1 n
FOR k OVER 1 k SUB REV DUP HEAD NEWOB SWAP /
b 1 k SUB * OVER REV * LSUM EVAL +
NEXT NIP TAIL
IMLXF
\<< LOGXF DUP SIZE 1. - R\->I LSEQ 1 :: * Scanl 2.
\<< / EVAL
\>> DOLIST
END
