11-26-2019, 04:24 PM
There's nothing novel here from a mathematics standpoint - it's just the same old mod-30 sieve we've been doing for decades. Rather, I found a way to use matrices on the 42S to do the trial divisions much faster.
Here's the code with some C-like comments:
"SS" and "RS" are the save-stack and restore-stack routines I have on my 42S. You can remove/substitute these calls as needed.
Variables, registers, and flags:
The basic idea is that rather than repeatedly doing 4, XEQ 01, 2, XEQ 01, 4 XEQ 01... making 8 calls in each loop, all the trial divisors are stored in a matrix and divided all at once. Then FP takes their fractional parts, and the undocumented matrix function [MIN] identifies any of the divisions with no remainder. Found factors get fully divided out and displayed, and if none are found, 30 is added to the divisor matrix and the loop repeats. This continues until the divisors exceed the square root of the remaining product, or the input number has been fully factored down to 1.
A couple of informal timing tests of factoring 9,999,999,971:
Original mod-210 factor finder with incr. XEQ - 1m30s
New matrix-based mod-30 factor finder - 53s
I got the idea from a TI-84 factor finder that uses essentially the same technique with lists. It dawned on me that it could be done with matrices on the 42S.
The code is still kind of rough and unrefined, but I'm seeing execution times cut as much as in half for certain inputs. I haven't yet tried extending this into a full mod-210 algorithm, so there may be more speed gains to be had yet. It would require larger divisor and remainder matrices, though, so more memory would be required to run the program.
LBL "FACTOR"
XEQ "SS" //Save stack
//Store number to factor, and its square root
STO 01
SQRT
STO 04
//Initialization
CLA
SF 01
CF 09
//Create the matrix for the first 4 divisors
4
1
DIM "D"
INDEX "D"
J-
0
2
XEQ 00
1
XEQ 00
2
XEQ 00
2
XEQ 00
STO 00
//Main loop
LBL 01
FS? 09 //Completely factored?
GTO 09 //Go to exit routine.
//Divide the remaining product by all divisors and store fractional parts in "R"
RCL 01
RCL "D"
FP
STO "R"
//See if any remainder is 0
INDEX "R"
[MIN]
X=0?
GTO 02
//See if the current max divisor is greater than the square root
RCL 04
RCL 00
X>Y?
GTO 06
//First time through the loop, go set up the matrix for the next 8 divisors
FS?C 01
GTO 10
//Otherwise add 30 to all divisors for the next loop
30
STO+ "D"
STO+ 00
GTO 01 //Back to the start of the loop.
//Main loop ends here.
//Last factor is the remaining product
LBL 06
RCL 01
AIP
AVIEW
GTO 09
//Factor out the current divisor
LBL 02
RDown //Get the divisor that corresponds to the zero remainder from trial division
1
INDEX "D"
STOIJ
RCLEL
STO 02
CLX //Initialize factor's power to zero
STO 03
LBL 03 //Divide out factor as many times as possible
RCL 01
RCL 02
MOD
X≠0?
GTO 04
LASTX
STO÷ 01
1
STO+ 03
GTO 03
LBL 04 //Display update routine
RCL 02
AIP
1
RCL 03
X>Y?
X>Y?
AIP
1 //Check if fully factored
RCL 01
X=Y?
SF 09
SQRT //Update the square root of remaining product
STO 04
FC? 09 //Append "×" if there are more factors
AVIEW
GTO 01 //Go make another pass with the same set of divisors
//Add the next divisor to the divisor matrix using increment in X
LBL 00
STOEL
J-
RTN
//Create the 8-element divisor matrix for passes 2+
LBL 10
8
1
DIM "D"
INDEX "D"
J-
RCL 00
4
XEQ 00
2
XEQ 00
4
XEQ 00
2
XEQ 00
4
XEQ 00
6
XEQ 00
2
XEQ 00
6
XEQ 00
STO 00
//Exit & cleanup
LBL 09
CF 01
CF 09
XEQ "RS" //Restore stack
END
Regs
00 - Current max divisor
01 - Number to factor/remaining product
02 - Current divisor/factor
03 - Power of current factor
04 - Square root of number to factor/remaining product
Flags
01 - First pass
09 - Fully factored
Variables
"D" - Divisors
"R" - Remainders
