11-19-2019, 08:59 PM
Is there somewhere a list of HP-41 XROM numbers for the synthetic instructions, including such as byte jumper, byte grabber, Q-loader etc?
Thanks and greetings,
Juergen!
Juergen!
(11-20-2019 02:46 PM)Sylvain Cote Wrote: [ -> ]Synthetic Instructions XROM, where is this coming from ?
First look into bytes encoding make no sense, need to look deeper into this.
After 40 years, I still discover things on the HP-41 ... or re-discover due to ageing
i: (fcnCode & 0xfc0) >> 6
j: (fcnCode & 0x3f)
(0xf73f & 0xfc0) >> 6 -> 28 (decimal)
(0xf73f & 03f) -> 63 (decimal)
(11-20-2019 03:27 AM)rprosperi Wrote: [ -> ]From p. 37 of Jeremy Smith's Synthetic QRG:Great, thanks! That helps a lot!
Byte Jumper: 05,01
Byte Grabber (7-byte): 28,63
Byte Grabber (3-byte): 15,48
NOP (Text 0): 03,48
E, Q Loader: 44,04
LBL Q Loader: 52,04
hth
(11-20-2019 05:52 PM)hth Wrote: [ -> ]Thanks for the explanation! Just for your information, there is also a dedicated chapter on this subject in Keith Jarret's "HP-41 Synthetic Programming made easy" on p. 86 ff, Chapter 4C, Pseudo-XROM previews, explaining the "assignments" XROM-Number <-> instruction in a mathematical way. Nice reading.(11-20-2019 02:46 PM)Sylvain Cote Wrote: [ -> ]Synthetic Instructions XROM, where is this coming from ?
When you press a key assignment, the 2-byte function code has its highest nibble inspected. If it is non-zero, it is assumed to be a 2-byte XROM.
Knowing this, we want to display the function name, but as it is an XROM it needs to scan for it using GTRMAD. For a 2-byte synthetic assignment, this will interpret the real function code (RCL M or whatever) as an XROM, extracting the ROM ID and function number (it assumes it is in A000-A7FF range, but that is not checked as it cannot happen in the normal HP-41).
GTRMAD will most likely fail to find a matching function and this is reported back. We now want to display the function anyway (the case where the key is being held for NULL test), so we go to XROMNF to display it as and XROM with numbers. This makes use of that GTRMAD always output the split up ROM Id and function code, even when it fails.
The formula used internally (in GTRMAD) for taking a two-byte instruction and getting the XROM i,j is:
j: (fcnCode & 0x3f)
So for a 7-byte byte grabber we often use F73F (to get a question mark in the inserted alpha string literal, mainly for easy recognition):
Thus, we will see XROM 28,63.
Technically, the 0xfc0 constant should be 0x7c0 for a correct number. However, the code assumes valid input (A000-A7FF), so it makes use of that knowledge save some MCODE instructions. This is why you may see XROM Id above 31 for such synthetic instructions.
Byte Jumper: 05,01
NOP (Text 0): 03,48
E, Q Loader: 44,04
LBL Q Loader: 52,04
hth
(11-22-2019 11:00 PM)rprosperi Wrote: [ -> ]I just copied some of the notes from Jeremy's SQRG, which lists entries intended for the "MK" (Make Key assignments) program. There are various Q loader variants listed; I don't recall the differences/functions among these Q-Loaders, however the 2 lines that have the XROM indicated are:
E. Q loader 44,04 Reference noted is p.283 of the PPC ROM manual (notes on using MK)
LBL Q loader 52,04
The entry for simple Q loader does not have an XROM equivalent listed, but has references to section 5I on p. 55 in Wickes' book, and SPME, section 4B on p. 77 (though page references vary between the 2 versions of the book published; I'd guess this is for the earlier edition, but section 4B is hopefully the same).
