Full Version: Saturn Emulator
Just wondering if Prime could run SATURN CPU emulator just like HP50G does ?
Source : https://www.hpmuseum.org/cgi-sys/cgiwrap...ead=124202
The HW is definitely powerfull enough to do so...
HPP is most likely too slow to do it at a speed close to what is needed :-( especially as it does not have anything that can simulate the memory while being fast...
Bit it would be interesting to think about what 4 or 5 instructions would be useful to speed things up significantly... and make it possible...
the 50G has around 2MB of ram space, which would easely fit in Prime (G2), so it should be more or less possible.
The main issue as far as I can tell is memory access (nibble read/write access) and nibble wise manipulations (in HEW and DCB)...
Cyrille
(11-12-2019 06:08 AM)cyrille de brébisson Wrote: [ -> ]Hello,
Cyrille
What if you waste memory by storing each nibble into a byte?
hello,
That helps the read/write, BUT, it means that each nibble has to be handled individually instead of being able to be handled as packs.
For example, if you work with "packed" nibbles, you can describe 1 register as 1 64 bit integer (and use masks), so any saturn binary operation can be done in basically 1 PPL line as in: A:= (A and not mask) OR ((A and mask) + (B and mask));
regardless of the field...
Working nibble by nibbles means loops, which are much less efficient...
Cyrille
(11-13-2019 06:09 AM)cyrille de brébisson Wrote: [ -> ]hello,
Cyrille
I C... masks are easy... thus:
It looks like every odd nibble read (ARM read is in bytes) has to be in a buffer
in order to combine it with "upper" 4 bits of the unaltered Saturn information
producing an even number of nibbles (= a byte).
Every odd nibble write needs first a read into a buffer before the write
to yet again combine the just read upper part of the byte with the 4 bits of that odd nibble
to get a full byte to be written.
Was that an explanation that others in this group can understand?
Is that how you did it with the HP 49/50 ARM version, Cyrille?
Thank you Cyrille for the informations, this is very interesting I like it !
Long life HP calcs !
Julien
Working with packed nibbles is faster because masks and the like help a lot with all the ASM operations... speeding them up tremendously...
It does make memory access more difficult, BUT in real life, I discovered (stats) that only a relatively small % of the instructions were memory access... so it is OK to take a penalty there...
One exception of course is the reading of instructions for execution, BUT this is a known linear process, so you can manage have a shifting buffer that will do rom read only every 8 nibbles or so to speed this up...
Cyrille
(11-14-2019 06:51 AM)cyrille de brébisson Wrote: [ -> ]Hello,
Cyrille
So...we will soon have a HP 50G+ Emulator running on the G2 hardware?
Even a small, even fee seems reasonable (10 USD? - 9 would be odd)
VPN
(11-14-2019 10:15 AM)CyberAngel Wrote: [ -> ]So...we will soon have a HP 50G+ Emulator running on the G2 hardware?
Odd, yes, but it wouldn't be Prime...
(11-14-2019 02:47 PM)grsbanks Wrote: [ -> ]
Then the price of that software should be even 2 USD
since 2 is - odd enough - the only even prime.
On the other hand - that software emulates HP 50g - shouldn't it cost 50 USD
Ba-dump-bump! Ouch...
Quote:So...we will soon have a HP 50G+ Emulator running on the G2 hardware
How would the vastly different keyboards be handled?
Technically, it is feasible... especially on G2.
Doing it in native C would be best of course, but means that Tim or I have to do it as it needs to be build in rom... and we are time limited...
Doing it in PPL would be much slower, but means that others can work on it. We could include some helper PPL functions to help speed things up (a little bit like what I did with the triangle/lines function used by Han's 3D graphing app)... But these functions would need to be well defined in advance...
Cyrille
You can look at HP prime HP41 emulator for a nut cpu emulator in PPL
This can help to start a saturn emulator, but it will be very slow. As C helper functions you need at least functions to deal with all registers ops (taking care of base and fields)
You need also to have a G2 hardware working at the same speed all the time ...
Case select should be also speed up a bit
Olivier
(11-15-2019 06:05 AM)cyrille de brébisson Wrote: [ -> ]Technically, it is feasible... especially on G2.
Cyrille
A Prime [+] with double^2 the screen resolution (and larger battery?) is easier to get
than a full Saturn Emulator with the latest HP 50g Firmware.
Tim will probably have the Emu ready when he is 50 ປີ.
[Forget the PPL - it's way too slow]
VPN
