10-25-2019, 03:40 PM
This program performs a few specific IP address/subnet calculations:
1. Convert a subnet mask to the corresponding CIDR suffix, and vice versa (e.g. 255.255.0.0 <-> /16)
2. Calculate the total number of host addresses available for a given subnet mask
3. Determine the network address for a given IP address and subnet mask pair
4. Determine the broadcast address for a given IP address and subnet mask pair
Usage
XEQ "IPADR" to start the program. All functions are carried out from a single menu.
The "ADDR", "MASK", and "CIDR" keys allow for entry or calculation/display of the IP address, subnet mask, or CIDR suffix respectively. These work like typical solver menu keys. When pressed after entering data, they store the value. When pressed without data, they calculate/display the result.
The "HOSTS", "NET", and "BCAST" keys calculate (i.e. they are read-only) the total number of host IP addresses available, the network address, and the broadcast address respectively.
To enter an IP address or subnet mask, use all four levels of the stack to enter an address. Essentially, you press ENTER instead of putting decimal points between the bytes. T should contain the first byte (0-255), Z the second byte, and so on.
The subnet mask and CIDR suffix will be automatically calculated whenever the other is entered. CIDR will only be calculated if all 1 bits in the subnet mask are left-aligned. In cases where the subnet mask is not left-aligned (e.g. 255.0.255.0), CIDR will be shown as 0.
Calculating "HOSTS" requires entry of either "MASK" or "CIDR".
Calculating "NET" or "BCST" requires entering "ADDR" and either "MASK" or "CIDR". Note that these can still be calculated normally even if you enter a network or broadcast address for "ADDR". You don't have to enter a host address.
Examples
1. Calculate the CIDR suffix that corresponds to the subnet mask 255.255.240.0.
255 [ENTER] 255 [ENTER] 240 [ENTER] 0 ["MASK"] : MASK=255.255.240.0
["CIDR"] : CIDR=20
2. Calculate the subnet mask for the CIDR suffix /18.
18 ["CIDR"] : CIDR=18
["MASK"] : MASK=255.255.192.0
3. Determine the number of possible hosts on a network with subnet mask 255.255.254.0.
255 [ENTER] [ENTER] 254 [ENTER] 0 : MASK=255.255.254.0
["HOSTS"] : HOSTS=510
4. Determine the subnet mask, network address, and broadcast address for a station with IP address 172.16.1.108/22.
172 [ENTER] 16 [ENTER] 1 [ENTER] 108 ["ADDR"] : ADDR=172.16.1.108
22 ["CIDR"] : CIDR=22
["MASK"] : MASK=255.255.252.0
["NET"] : NET=172.16.0.0
["BCST"] : BCAST=172.16.3.255
Program Code
[attachment=7745]
Usage
Examples
["CIDR"] : CIDR=20
Program Code
00 { 446-Byte Prgm }
01▸LBL "IPADR"
02 CLMENU
03 "ADDR"
04 KEY 1 XEQ 01
05 "MASK"
06 KEY 2 XEQ 02
07 "CIDR"
08 KEY 3 XEQ 03
09 "HOSTS"
10 KEY 4 XEQ 04
11 "NET"
12 KEY 5 XEQ 05
13 "BCST"
14 KEY 6 XEQ 06
15▸LBL 00
16 MENU
17 STOP
18 GTO 00
19▸LBL 01
20 FC?C 22
21 GTO 11
22 XEQ 10
23 STO 01
24 XEQ 30
25 STO 02
26▸LBL 11
27 "ADDR="
28 RCL 01
29 XEQ 40
30 AVIEW
31 RTN
32▸LBL 02
33 FC?C 22
34 GTO 12
35 XEQ 10
36 STO 03
37 XEQ 30
38 STO 04
39 0
40 STO 05
41 R↓
42 NOT
43 XEQ 50
44 1
45 +
46 LOG
47 2
48 LOG
49 ÷
50 1ᴇ-9
51 +
52 ENTER
53 FP
54 2ᴇ-9
55 X<Y?
56 GTO 12
57 R↓
58 R↓
59 IP
60 32
61 X<>Y
62 -
63 STO 05
64▸LBL 12
65 "MASK="
66 RCL 03
67 XEQ 40
68 AVIEW
69 RTN
70▸LBL 03
71 FC?C 22
72 GTO 13
73 STO 05
74 32
75 X<>Y
76 -
77 2
78 X<>Y
79 Y↑X
80 1
81 -
82 NOT
83 XEQ 50
84 STO 04
85 XEQ 31
86 STO 03
87▸LBL 13
88 "CIDR="
89 RCL 05
90 AIP
91 AVIEW
92 RTN
93▸LBL 04
94 RCL 04
95 NOT
96 XEQ 50
97 1
98 X<>Y
99▸LBL 14
100 ENTER
101 ENTER
102 2
103 MOD
104 1
105 +
106 STO× ST Z
107 R↓
108 2
109 ÷
110 IP
111 X>0?
112 GTO 14
113 R↓
114 2
115 -
116 "HOSTS="
117 ARCL ST X
118 AVIEW
119 RTN
120▸LBL 05
121 RCL 02
122 RCL 04
123 AND
124 XEQ 31
125 "NET="
126 XEQ 40
127 AVIEW
128 RTN
129▸LBL 06
130 RCL 02
131 RCL 04
132 AND
133 RCL 04
134 NOT
135 XEQ 50
136 OR
137 XEQ 31
138 "BCAST="
139 XEQ 40
140 AVIEW
141 RTN
142▸LBL 10
143 STO 06
144 R↓
145 1ᴇ3
146 ×
147 STO+ 06
148 R↓
149 1ᴇ6
150 ×
151 STO+ 06
152 R↓
153 1ᴇ9
154 ×
155 RCL 06
156 +
157 RTN
158▸LBL 30
159 1ᴇ3
160 STO 07
161 R↓
162 256
163 STO 08
164 R↓
165 GTO 32
166▸LBL 31
167 256
168 STO 07
169 R↓
170 1ᴇ3
171 STO 08
172 R↓
173▸LBL 32
174 3ᴇ-3
175 STO 00
176 R↓
177 0
178 STO 06
179 R↓
180▸LBL 33
181 ENTER
182 ENTER
183 RCL 07
184 MOD
185 RCL 08
186 RCL 00
187 IP
188 Y↑X
189 ×
190 STO+ 06
191 R↓
192 RCL 07
193 ÷
194 IP
195 ISG 00
196 GTO 33
197 RCL 06
198 RTN
199▸LBL 40
200 ENTER
201 ENTER
202 1ᴇ9
203 ÷
204 XEQ 41
205 ├"."
206 XEQ 41
207 ├"."
208 XEQ 41
209 ├"."
210 XEQ 41
211 R↓
212 RTN
213▸LBL 41
214 AIP
215 FP
216 1ᴇ3
217 ×
218 RTN
219▸LBL 50
220 2
221 32
222 Y↑X
223 1
224 -
225 AND
226 END
[attachment=7745]
