10-23-2019, 04:06 AM
Four algorithms I've been using. Convert partial quotients to fractional and vice versa. Also convert surd to partial quotients and vice versa. These do work with big integers. I tested the fraction and partial quotients with numbers bigger than 2^64.
->Frac
Input: list of integers representing the partial quotients of a continued fraction. HP50g
Output: a list of the continued fractions exhibited for each partial quotient. (All fractional, no improper fractions.)
Input is echoed.
« DUP SIZE LASTARG { 0 1} {1 0} -> N A P Q
« 1 N FOR I A I GET DUP
P HEAD * P 2 GET + P + 'P' STO
Q HEAD * Q 2 GET + Q + 'Q' STO
NEXT P Q / 1 N SUB » »
This just uses the usual recursion. Making P and Q a single list with two elements runs slower (even though one can do the arithmetic using list operations.)
Frac->
Input: fraction. (Like '30/101'). Input is echoed. Trivial to change to pair of numbers or even to sort the pair.
Output: list of partial quotients; first entry is the integer part.
« DUP FXND -> A B
« {} WHILE B REPEAT
A B IQUOT + A B MOD
B 'A' STO 'B' STO
END » »
Repeated Euclid's Algorith. IDIV2 is very slow. IREMAINDER slower than MOD. Also / and FLOOR slower than IQUOT.
Perhaps different size numbers would change the results.
Lagrange's therorems show that every periodic continued fraction is a quadratic irrational (old name was "surd"). Also every quadratic irrationsl (A+Sqrt(D))/C yields a continued fraction.
The next to programs compute these results.
->Surd
Input is a list of partial quotients making up the periodic part of the quadratic irrational. (Doing the aperiodic stuff was too hard and I didn't need it.)
Output is a number of the form: (A+Sqrt(B))/C.
« DUPDUP SIZE IF 1 == THEN DUP + END ->Frac
1 2 SUB FXND EVAL -> P2 Q2 P1 Q1
« P1 Q1 - DUP SQ Q1 P2 * 4 * + SQRT + 2 Q1 * / EXPAND » »
Surd->
Input: quadratic irrational ( A + Sqrt(D) / B )
Output: list of partial quotients. First entry is integer part. Then, list of aperiodic part (no list if none). Followed by periodic part.
« DUP 0 {} 0 0 -> X A S N M
« EXPAND DUP FLOOR DUP 1 ->LIST 'A' STO - EXPAND DUP
DO 'S' STO+ INV DUP FLOOR DUP 'A' STO+ - EXPAND DUPDUP
S SWAP POS DUP 'N' STO UNTIL END
DROP2 X A REVLIST HEAD A SIZE DUP 'M' STO N -
IF 1 > THEN A N 1 + M 1 - SUB REVLIST 1 -> LIST + N END
A 1 N SUB REVLIST + » »
A bit slow as the program checks for a cycle completion at each new generated partial quotient.
Algorithm is to iterate the Gauss Map: X = FRAC( 1 / X ).
There are some faster stuff but they just get partial quotients ignoring the aperiodic stuff.
->Frac
Input is echoed.
Frac->
« DUP FXND -> A B
« {} WHILE B REPEAT
A B IQUOT + A B MOD
B 'A' STO 'B' STO
END » »
->Surd
Surd->
