I just got an fx-CG50 and updated it to OS 3.30.0202 which includes Python.
when I try to list the built in functions I get this:
>>> import builtins
>>> dir(builtins)
MemoryError:
Does anyone else get this or is it a problem with my particular unit?
(10-08-2019 02:21 AM)toml_12953 Wrote: [ -> ]I just got an fx-CG50 and updated it to OS 3.30.0202 which includes Python.
>>> import builtins
>>> dir(builtins)
MemoryError:
I do not have this machine, but reading the user guide they mention that built-in commands can not be imported because they are, well, built in.
At page 17-9 Casio says:
1. On the script editor screen or SHELL screen press !e
(CATALOG).
This displays the catalog command list screen.
If you want to select a command on this screen for input,
go to step 4 of this procedure. If you want to select a
category, go to step 2 of this procedure.
2. Press 6(CAT).
This displays the category list.
For detailed information about each category, see
“Command Categories” (page 17-10)
And from there option 2 would list the built-in commands.
Does it work as advertised in your machine?
(10-08-2019 12:25 PM)jebem Wrote: [ -> ] (10-08-2019 02:21 AM)toml_12953 Wrote: [ -> ]I just got an fx-CG50 and updated it to OS 3.30.0202 which includes Python.
>>> import builtins
>>> dir(builtins)
MemoryError:
Yep, I can select items from the catalog and choose category, etc. If the import builtins command isn't supported then I wonder why I didn't get an error when I executed it. The error didn't happen until I tried to list the built in commands with dir().
