09-29-2019, 07:33 PM
Although this would usually go to "Not quite HP Calculators...." I post this addendum here because it fits the overall discussion of HHC 2019.
I got some feedback on forum.swissmicros.com wrt my talk about the WP43C. The most important was from Jaco highlighting the issue of overlay/faceplate that might be of interest. here is his comment
The two different labels mentioned above can be seen here. Then you see that the final (tentative) label for the WP43C (not be mixed with the WP43S) differs from that I presented at the HHC. Layout 1A on the left, Layout L2 on the right. Layout L2 as I showed at the HHC (with blue functions/menus) can be seen here.
Hope that helps,
Günter
...and doesn't add to the confusion
Quote:From Jaco Mostert:
No major issues in the talk, the only one worth mentioning the status of the layouts, let me summarise:
WP43C Layout 2 is the one demo’d at hhc. No issues. No template is needed nor planned. This layout also contains the expanded HOME menu with the blue label indexes.
WP43C Layout 1A is a slight variation on L2 where less of the yellow labels correspond with DM42. Because of that, this one needs a printed template and a template is planned. Design is in progress. Material of the template is not yet finalised. SwissMicros stated they will make a template.
Hope that helps,
Günter
