02-28-2021, 02:15 AM
03-01-2021, 05:59 PM
(02-28-2021 02:15 AM)DM48 Wrote: [ -> ]Anyone know how to import a program from m48+ to iHP48? I have the object file but can't find a way to get into iHP48.
Dear DM48,
I have added two options to interact with Apple interfaces. Those options rely on:
- iTunes to use a PC to download / upload the files or
- Apple Files app (on iOS). With this app you can copy / move files from another app of from almos any popular cloud service such as iCloud of course, OneDrive, DropBox and others.
With these options you can enable the file on the iHP48 filespace, and then use the "Load Object ..." menu option within the iHP48 app.
Hope it helps.
Alexis
03-01-2021, 07:34 PM
(03-01-2021 05:59 PM)Artista Wrote: [ -> ](02-28-2021 02:15 AM)DM48 Wrote: [ -> ]Anyone know how to import a program from m48+ to iHP48? I have the object file but can't find a way to get into iHP48.
Dear DM48,
Hope it helps.
Alexis
Alexis, thank you for the reply. I have the Files App installed on my iPhone and the *.obj file stored inside iCloud Drive.
*** Ignore this***
How do I enable the file on the iHP48 filespace? I must be overlooking how to do this.
*** Ignore this END ***
I see now. With out your advice, and taking some time to study this, I don't think I would have figured that out. I have it now. There is an iHP48 folder ON the iPhone within the Files app.
iHP48 is a life saver and a donation was sent. THANK YOU!
03-06-2021, 11:57 AM
That’s great news with the iHP48!
I just downloaded and installed it on my iPhone 7+.
I still have the original m48+ installed and wonder how to transfer the “steel” skins.
There’s one that uses the full screen resolution of the iPhone 6/7/8+ and to what I understand gives the same functionality as the Don’t Panic skins.
Thanks in advance for any assistance.
03-06-2021, 03:05 PM
Open the Files app on your iPhone. From the top menu (iCloud Drive, On My iPhone, Dropbox, etc will be listed), choose on your iPhone. See the iHP48 Folder. Copy any file you have into this directory/sub-directory and you will be able to access that file from the calculator menu by double tapping the screen.
Does that help?
Does that help?
03-06-2021, 09:22 PM
I used imazing to copy the steel skins from the m48+ to the PC and then from the PC to the iHP48. So far so good, but trying to open one of the steel skins gives me an error message. I don't know why.
03-06-2021, 09:25 PM
Which skin?
03-07-2021, 01:30 PM
(03-06-2021 09:25 PM)DM48 Wrote: [ -> ]Which skin?
The file name is:
/Skins/HP48G/Steel48GX_v2-736h@3x.xml
The title is:
Steel48GX_v2 (iPhone 6+)
The message I get when trying to change to this skin is:
Quote: Error!
This <sensorpreset> is unknown.
Error parsing <sensorpreset>.
Error parsing <sensors>
Error parsing <button>.
Error parsing <buttons>
Error parsing <orientation>.
Error parsing <orientations>.
Error parsing XML file.
04-05-2021, 03:12 PM
iHP48 is great!
But how do I install Meta Kernel?
(I have an old configuration from my m48+ with MK2.29 installed but that crashes in iHP48 and I should probably start fresh.)
04-05-2021, 03:28 PM
(04-05-2021 03:12 PM)Orome Wrote: [ -> ]But how do I install Meta Kernel?
I found instructions, but can't get them to work (even after sorting out the confusing line breaks and step numbering errors):
- Create a new HP48GX calculator
- Type MERGE1 into the calculator (without the "") and press [ENTER]
- Go to Fetch... and download the Meta-Kernel from the web
- Now use the Load Object... function to load the following file into the calculator: /Downloads/MetaKernel2.30/Disk/Install/MKRAM.KER
- Go to the calculator
- Type 'M' and hit [STO]
- Type again 'M' into the stack for later. An 'M' should reside on the stack.
- Load Object ... the following file /Downloads/MetaKernel2.30/Disk/Install/RECV.KER
- Hit [EVAL]
- WAIT for the installation to finish. It will reboot the calculator automatically at the end.
- Install any library on port 0 after the completion of this procedure.
After hitting [EVAL] (step 10 above) I get
THEN Error:
Too Few Arguments
Also, what should actually be on the stack for steps 6 and 7: M or 'M'?
(Crossposted here)
05-04-2021, 01:50 PM
iHP48 is great. Has anyone found a good skin for the iphone 12 pro? Something that pretty closely replicates the real thing (48G or GX) without screen stretching, etc?
Don't really want to go through all 100+ total skins to find one that looks right.
05-21-2021, 07:08 AM
Could someone get an m48 IPA from their device and post somewhere? I understand this will install via iTunes only if purchased the app anyway. I upgraded to a new iPad Pro and was dumb enough to reset the old iPad before I realized the m48 icon was just a stupid download link
