09-09-2019, 08:50 PM
09-09-2019, 08:53 PM
PPLX v0. 1 provides implementation limits and TYPE's.
Implementation limits were tested on the Android VC: The values applicable to actual calculators and older firmware may differ.
LOCAL CRID:="PPLX V0.1 © 2019 StephenG1CMZ";
LOCAL NA:="(N/A)"; //NOT APPLICABLE
LOCAL SP:=" ";
//Returns the type of the object:
EXPORT TYPEREAL :=TYPE(3.1); //0: Real
EXPORT TYPEINT :=TYPE(#3); //1: Integer
EXPORT TYPESTR :=TYPE("A"); //2: String
EXPORT TYPECMPLX:=TYPE(); //3: Complex
EXPORT TYPEMAT :=TYPE([1]); //4: Matrix
(inc vector)
EXPORT TYPEERR :=5; //5: Error
EXPORT TYPELST :=TYPE({}); //6: List
(inc set)
EXPORT TYPECAS :=TYPE(CAS("nop")); //7 CAS
EXPORT TYPEFUN :=TYPE('X'); //8: Function
EXPORT TYPEUNIT :=TYPE(1_m); //9: Unit
//14.?: cas object. The fractional part is the cas type.
EXPORT ALLTYPES :={TYPEREAL,TYPEINT,TYPESTR,TYPECMPLX,TYPEMAT,TYPEERR,TYPELST,TYPECAS,TYPEFUN,TYPEUNIT};
EXPORT TYPEIDS :={"HomeSet_Real","HomeSet_Integers","Main_String","HomeSet_Complex","HomeSet_Matrix","AppData_ErrorPrefix","HomeSet_List","HomeSet_CAS","Program_Function","Units_Unit1"}; //MIXED STRINGFROMID
//Implementation Limits-Runtime
//(Empirical on Android unless stated)
//NB workarounds may exist, eg to create larger strings
//EXPORT ImpREAL:={MIN(MAXREAL,CAS(maxreal),MINREAL});
LOCAL ImpINTb:=32; //STANDARD. MAX 64
EXPORT ImpINT:=2^(ImpINTb-1);//{default 32,max 64,Less 1 when signed}
EXPORT ImpSTR:=32*1024;//64KB
//EXPORT ImpCMPLX:="TBD";
EXPORT ImpMATSZ:= 20000-1;//TOTAL NUMBER OF ELEMENTS (MAT OR VEC)
//NOTE: use of mat2list may require ImpLST instead
EXPORT ImpMATSQ:= 141 ; //141*141<20000
EXPORT ImpLST := 10000; //STATED
EXPORT ImpMATSL:=MIN(ImpMATSZ,ImpLST);//safe limit if mat2list may be invoked
EXPORT ImpCHOOSE:=2047; //EG SEE TOWER OF HANOI
EXPORT ImpPRINT:=64;//ANDROID LIMIT: 64 MB CHARACTERS
//Implementation Limits:Compiletime
LOCAL ImpCASE:=127;//INCLUDES ANY DEFAULT
EXPORT ALLImps:={{MAXREAL,MINREAL},{ImpINTb,ImpINT,STRINGFROMID("Modes_Standard")},(ImpSTR*2/1024)+" KB "+(ImpSTR)+" "+STRINGFROMID("Chars_Title"),,{ImpMATSQ+"*"+ImpMATSQ,ImpMATSZ},NA,ImpLST,NA,NA,NA,ImpCHOOSE,ImpPRINT+" MB"};
EXPORT ABOUT()
PRINT();
PRINT(CRID);
PRINT("Useful extras that might have been useful in PPL.");
PRINT("Note that Implementation Limits may have workarounds.");
//Many programs need this info
WAIT;
EXPORT TYPENAME(TYPNUM)
//Return name of TYPE
RETURN IFTE(TYPNUM<SIZE(TYPEIDS),STRINGFROMID(TYPEIDS(TYPNUM+1)),STRINGFROMID("Main_InvalidInput"));
//UI OUT
EXPORT STPAD(ST,LNG,DD)
//CONSTRUCT A PADDED STRING (SPACES)
//ST TO BE PADDED NOT TRUNCATED
//LNG IS MINIMUM LENGTH
//DD: DIRECTION 1 RIGHT −1 LEFT 0 CENTRE
LOCAL LL:=ABS(IP(LNG));//INGUARD
LOCAL SPC:=LL-DIM(ST);
LOCAL SPTMP:="";
CASE
IF DD>0 THEN //PAD R
RETURN REPLACE(ST,LL+1,"");//SYN:JOE HORN
IF DD<0 THEN //PAD L
RETURN REPLACE("",SPC+1,ST);
DEFAULT //PAD C
SPTMP:=ZPAD("",SPC/2,1);//spaces
SPTMP:=SPTMP+ST+SPTMP;
RETURN
IFTE(DIM(SPTMP)<LL,SPTMP+" ",SPTMP);//extra space if odd
END;//CASE
EXPORT OutImpLimits()
//Display Implementation Limits
LOCAL II;
LOCAL LH:=17;//LINEHEIGHT
LOCAL IDS:=CONCAT(TYPEIDS,"Main_CHOOSE","PRINT");
RECT_P();
TEXTOUT_P(STRINGFROMID("Main_Program")+" "+STRINGFROMID("Toolbox_Limits")+" (PPL)",0,0);
//MSGBOX(IDS(0));
//PRINT(IDS);WAIT;
FOR II FROM 1 TO SIZE(ALLImps) DO
//MSGBOX((IDS(II)));
TEXTOUT_P((II-1)+" "+STRINGFROMID(IDS(II)),0,LH*II);
//IF ALLImps(II)≠NANS THEN
TEXTOUT_P(ALLImps(II),320/3,LH*II);
//END;
TEXTOUT_P("PRINT",20,12*LH);
WAIT;
EXPORT PPLX()
LOCAL ST;
//PRINT();
//PRINT(CRID);
ABOUT();
IF 0 THEN //TEST ImpPRINT
ST:=STPAD("ACD",64*1024*1024,1);
PRINT(DIM(ST)/1024/1024);
PRINT(ST);
PRINT("OK");
